Turbo kits .com kit pics
Old Sep 8, 2004 | 02:03 PM
  #136
Boeturbolancer's Avatar
Eliminating a factory fan is not recommended... that is why you should install another fan if you take out the stocker. Doesn't hurt to be safe. One fan in 90 degree weather will put a hurt on the motor. Your water temp might not reflect it as much since it's just an dummy gauge anyway, but the engine will know/feel the rise in temp and suffer from it.
Dookie, no worries i just don't want you getting into anything that might cause more problems later. I figure just come out and we'll get you going right. I know it's kindof a pain but since your relatively close it's also a great advantage. See ya soon.
Old Sep 8, 2004 | 04:24 PM
  #137
pgmike's Avatar
boe so we should replace teh stock fans with two slimline fans, not jsut one?
Old Sep 9, 2004 | 12:28 AM
  #138
Dookie's Avatar
The turbo only needs room for the right fan to be relocated. On my car at least, both fans run at a slow speed with the A/C off whenever the coolant temp gets too hot. Then when the A/C is on, both run at high speed. So actually, both fans serve a cooling purpose, A/C or not....
Old Sep 9, 2004 | 02:00 AM
  #139
RollerPyro's Avatar
Hmm I don't know how I missed this thread all this time, but I know a guy who's had the TSI kit for a long time. He's had trouble with it from the start if i remember right. The install was difficult and required some custom work I think. Right now he's got a boost leak.
Old Sep 9, 2004 | 05:43 AM
  #140
airlinevomitbag's Avatar
Dummy gauge or not you open his hood after pounding on it and its cooler than my car after its been idling for 10mins. My opinion is if it's intercooled and your cooling system is in decent shape it doesn't really need that other fan, his EGT is more than 200 degrees cooler than it was NA. Cooler air in cooler air out.
Old Sep 9, 2004 | 08:18 AM
  #141
Hotshot940's Avatar
that blows my mind...
Old Sep 9, 2004 | 08:20 AM
  #142
livelyjay's Avatar
Doesn't running a little rich lower EGT temps as well?
Old Sep 9, 2004 | 08:22 AM
  #143
Hotshot940's Avatar
uh huh
Old Sep 24, 2004 | 01:32 AM
  #144
joshthegreat's Avatar
i have a question, where in the hell does the 1st O2 sensor go on the tsi kit?, i rode in dookies stage 2 rrm kit.....it was freakin awsome
Old Sep 24, 2004 | 07:28 AM
  #145
Got this off the first page... hope you can see it down there. Appears that you might have to extend the wiring to get to that point. They probably supply the wire you just cut/splice it in.
Old Sep 26, 2004 | 07:48 AM
  #146
Mitsubishi_03's Avatar
still no vids or dyno numbers??
Old Apr 3, 2005 | 06:09 PM
  #147
kbadboy's Avatar
does the check engine light come on with the tsi kit and it does or does call for a relocation of the stock cooling fans?
Old Apr 3, 2005 | 06:28 PM
  #148
Viciouz's Avatar
i think you have to relocate the fan and engine light might come on and you need to do a lot of custom fabrication for this kit
Old Apr 3, 2005 | 06:32 PM
  #149
kbadboy's Avatar
i here you can get a sensor to trick the ecu? and AS far as fabrication you just need a aftermarket front bumper
Old Apr 3, 2005 | 07:22 PM
  #150
initialDRacer's Avatar
its called O2 simulator.
