am i missing anything??
Old Sep 11, 2004 | 11:32 AM
Hotshot940's Avatar
Originally Posted by airlinevomitbag
And a FMU does exactly what? It regualtes and raises fuel pressure based on intake manifold pressure.
i obviously misunderstood you seeing as tho when i hear hear "fuel pressure regulator" i think of someone changing the fuel pressure regulator, but yes, you are right an FMU would be one form of changing fuel pressure that would work for up to about 7 psi.
Old Sep 12, 2004 | 09:07 AM
turbo03oz's Avatar
well i plan on running around 9 psi should i get the FPR instead of the FMU?
also if i get bigger injectors am i required to get a RRM piggyback?
Old Sep 12, 2004 | 10:45 AM
maxum17ft's Avatar
fmu and fpr are basically the same thing they used to be called fpr and are now called fmu's. they are both increasing the amount of fuel being fed into the motor when under boost. sum1 correct me if i am wrong. also i would get injectors for 9 psi and u dont neeeed a piggyback it just would be nicer to have.
Old Sep 12, 2004 | 10:51 AM
Megadeth2118's Avatar
The FMU is a fuel pressure regulator it just raises fuel pressure with boost pressure. 1 psi of boost = 12 psi of fuel.
I don't believe a piggyback is required with new injectors, but it would help even out the fuel curves.
heh beat me to it.
Old Sep 12, 2004 | 12:26 PM
Hotshot940's Avatar
if your going to run 9psi you will need the FMU + injectors.
Old Sep 12, 2004 | 10:24 PM
turbo03oz's Avatar
alright preciate the help
b1u3
Apr 11, 2016 07:27 PM
4G93Turbo
Northeast Region
Sep 17, 2012 05:30 AM
SuckaFree
11
Oct 11, 2008 10:12 PM
TKMotorsports
25
Mar 12, 2007 07:25 PM
IMPORTIMAGE
23
May 1, 2006 05:46 AM
