View Poll Results: Like it?
It's okay...
24
48.00%
Like it...
20
40.00%
Awesome!
10.00%
I absolutely can't live without it!!
2.00%
Voters: 50. You may not vote on this poll
Custom Fiberglass enclosure in trunk PIX!!
Old Nov 27, 2004 | 11:17 AM
  #31
sykou's Avatar
Unhappy
Originally Posted by SK Lancer
Either way, ditch the middle wooden box.
oh i just finished carpeting everything. so the wooden box is carpeted along with the corner enclosures. i built the amp cover but im not done making the cutout and the neon under... i couldn't find a carpet that is the exact same color as my trunk one so the one i used is the closest i could get my hands on.
Attached Thumbnails Custom Fiberglass enclosure in trunk PIX!!-center.jpg   Custom Fiberglass enclosure in trunk PIX!!-left.jpg   Custom Fiberglass enclosure in trunk PIX!!-right.jpg
Old Nov 27, 2004 | 11:43 AM
  #32
Marques's Avatar
nice bro
Old Nov 27, 2004 | 01:43 PM
  #33
fborg's Avatar
looks great!!!
Old Nov 27, 2004 | 01:56 PM
  #34
Blue04ES's Avatar
looks pretty nice!!
Old Nov 27, 2004 | 02:29 PM
  #35
sykou's Avatar
hey can someone fill me in on how many caps i need??? I think i need a cap cuz when i turn my amps on my headlights dim like crazy every time the bass hits. The cap is supposed to store power so your amps take the power from the caps and not your battery right? i was thinking of buying two caps and fiberglassing them both onto the empty spaces on the sides of my ported box, good idea??? or not???
Old Nov 28, 2004 | 12:41 AM
  #36
mitsurs01's Avatar
Honestly sykou, I would look into a second battery setup. The cap is only for energy spikes. It only helps in major power draws. It may help your lights a bit, but untimately you just need more power. A cap discharges very quickly, but charges very slowly, so over time you will still get some dimming. I would just recommend you do a second batt, saves more time and money and is MUCH more efficient.
Old Nov 28, 2004 | 01:05 AM
  #37
ilovecb23's Avatar
damn thats gonna look hot when you get it done
Old Nov 28, 2004 | 06:59 PM
  #38
SK Lancer's Avatar
OH MY GOD already...pick either the 10's or the 12!!! DITCH ONE OF THEM!!!!!!!!!!!
I'm sick of telling you this...omg...
end rant.
Old Nov 28, 2004 | 08:37 PM
  #39
mycarspimp's Avatar
Originally Posted by BillAce
Probably with different amps too. can you say Cancellation?
I agree doesn't seem like that would be good for clear sound but the box looks nice
Old Nov 29, 2004 | 11:47 PM
  #40
sykou's Avatar
yeah i agree but the sound quality wasn't my major goal i was just going for looks.
Old Nov 29, 2004 | 11:49 PM
  #41
sykou's Avatar
so a cap doesn't continuously give a constant charge to your amps...damm i had it all wrong.. ahhh!!!...so if i were to get a second battery could you give me a little insight on how i would possibly wire it. by wiring i mean hooking it up to the original batt. cuz i already did a battery relocation on my other car so i no how to do that but i just need to know whether/how to wire the batteries in series or parrallel.
Old Nov 30, 2004 | 01:14 AM
  #42
davyper's Avatar
looks nice
Old Nov 30, 2004 | 05:08 AM
  #43
KevinD's Avatar
wire them in parallel. wiring your batteries in series would make you car 24 volts and i don't think anything would like that.
Old Nov 30, 2004 | 07:26 AM
  #44
BillAce's Avatar
A second battery is a bad idea. Unless you listen to the stereo with the key off for extended periods, you create more problems than it's worth. I am moving my battery to the trunk and using one of these
www.bigampbatteries.com
It will more than double the instantaneous current of an Optima Yellow top and have much less of a voltage drop under load. The alternator only has to charge 1 battery less often since they regenerate a charge at rest. There will be a smaller version available soon, but it obviously won't have the same output potential.
After you bought 2 batteries, an Isolator, wiring and solenoid, you will spend more and create a bunch of new electrical problems in your car.
Old Dec 1, 2004 | 08:56 PM
  #45
4Gaijin63's Avatar
why wasnt there an option for "no" in your poll? not bashing but you asked for opinions and i dont like it.
