Alternator Output
Alternator Output
Just to let you guys know, the Alternator in the lancer produces 60amps @ 2000rpm. I had this checkout at my local Advance Auto Parts. This number is still good for cars our size, some produce just 30amps
well all I know is, they tested it using their roll out carts. I believe they're called an ARBST tester. They connected the clamps to the positive and negitive terminals and an amp "ring" around the negitive battery cable. I brough the car upto 2000rpm and held it there for a minute or so, the idle. I had my lights, stereo, and A/C on at the time. I do not belive those would case any different reading as the test is done right at the battery. The tester read 60 amps, and the alternator tested good. Maybe if some of you had the time, have your output tested at a local parts store and see what they read.
The Alternator is rated for maximum output which is 85A at 3K engine RPM typically you do this test at 2K though you are correct there but your idle amp per hour generation would be far less thatn 60A if I'm not mistaken.
Yeah for 400+ dollars Mechman.com
i bought a delco alternator, 200 amps, pushing my 12 w7's right now and my 1000 watt amp. my system is almost complete. should be done by wednesday =). gotta put in my 2 300x2's to push my inside speakers and i gotta buy a headunit. my alternator costed me $450 installed. but i got hooked up by a long time friend. the alternator is either delco or acdelco something like that
R/TErnie
190
May 22, 2026 07:59 AM
xfreakx
Aug 1, 2007 10:28 AM
Psythik
23
Oct 15, 2006 01:16 PM
good luck with your system!
