overcharge on my system
Old Jul 28, 2007 | 07:33 PM
xfreakx's Avatar
yes my battery light an brake came on my 05 ralliart then when popping my hood i noticed the harness melted down an the red top battery was releasing fluid. im running a 1800 rms an 400rms mtx amp an 2 12" mtx 8500 700watt power inverter. i know the ra's are 110 amp alternator im sure upgrading that to 170amp alternator is a good start an upgrading to the yellow top just kindin getting some ideas on witch is the best set up for this system so this wont happen again
Old Jul 29, 2007 | 08:41 AM
bruce988jl's Avatar
Wow i'm not too familar with audio setups but i've never heard of that happening before...
So you're sayin' that your stereo setup melted your battery?
Old Jul 29, 2007 | 11:16 AM
SLVROZ_03's Avatar
Not overcharging, definitely not...but was their any electrical issues that you've dealt with lately? Any electrical failures, faults, grounding issues, anything?
Old Jul 29, 2007 | 12:53 PM
otter's Avatar
EvoM Administrator
I think you've got more serious problems than just overdrawing power, though I think it's laughable that you even thought you could pull that much power in the first place off a stock alternator. You're going to need to upgrade a lot of wiring, you can't expect to move that kind of power without beefing up all the wiring to your alternator and all your ground points.
Old Jul 29, 2007 | 02:11 PM
SLVROZ_03's Avatar
^So true! More important than RMS though, what's the amperage draw from each amp? I had a 4-ch 6004 MTX and it drew 80 amps itself!!! and that's the 4-ch, not the sub amp.
Old Jul 29, 2007 | 03:42 PM
crazy4ozs's Avatar
agreed with all above, first of all, double ground everything, second, upgrade all your power wire/ ground wire/ and all engine compartment wiring to 0awg...3rd...get a new alternator
Old Jul 29, 2007 | 07:54 PM
benny_ralliart's Avatar
sounds like you have a lot of rewiring to do!
Old Aug 1, 2007 | 10:28 AM
xfreakx's Avatar
found the problem
now what happen was that the harness plug the conected to th alt melted from heat causing a short in the system that forced the alt to over charge causing the battery to explode. replaced the harness an alt an battery every thing is in good order now
RT78
Apr 19, 2016 01:55 PM
djblinx
Dec 6, 2010 03:21 PM
Planetz24
Mar 10, 2009 08:27 AM
btownsoccer22
22
Oct 17, 2008 07:35 PM
TheSeige
Aug 15, 2003 10:28 PM
