HU install question
Old Jul 12, 2006 | 01:08 PM
nem187's Avatar
HU install question
Just ordered a Kenwood KDC-X789. Just wondering if anyone knows how easy this install is. Will I need any adapters or will it be a plug and play deal? This will be my first HU install so any advice would be great.
Old Jul 12, 2006 | 02:00 PM
ThunderOZ's Avatar
adapter make life easier but if u never did an install before jst got pick up one...
Old Jul 12, 2006 | 02:24 PM
nem187's Avatar
Where should I pick one of those up? Crutchfield?
Old Jul 12, 2006 | 02:52 PM
davids2004's Avatar
I used the stock brackets to install my radio. Did not need a kit
Old Jul 12, 2006 | 08:41 PM
ThunderOZ's Avatar
i thought you were talking about the wiring...yea for mounting the stock brackets work but use the wiring harness for the well, wiring lol. crutchfield, circuit city, best buy, any audio place basically will carry it
Old Jul 12, 2006 | 08:53 PM
mscc04's Avatar
Install is easy. Pull off the climate control knobs by pulling them towards you. Take out the two screws behind the the knobs. Pull the trim piece around the HU and climate control towards you (might be a little hard the first time but don't break anything trying to pull it out too hard). Remove the four screws around the HU and pull the stock radio out. Remove the wiring harness and the antenna from the stock unit. Use the brackets on the sides of the stock unit for the aftermarket. If you have problems taking out the screws on the stock brackets take it in to Circuit City and they'll help you out. My screws started stripping when I tried taking them out (and I was using the correct size philips). This is how I did it for my '03.
Old Jul 12, 2006 | 09:00 PM
ThunderOZ's Avatar
yea mine started stripping as well so i got a drill and a saw and made a grove so i could use a flat head screw driver...what part of nova are you in?
Old Jul 13, 2006 | 10:49 AM
nem187's Avatar
I'm at Ft. Belvoir, right by Alexandria. I don't think the install will be too tough, just gotta go get a wiring harness when the HU gets here it looks like. Thanks for the help guys.
Old Jul 13, 2006 | 01:02 PM
davids2004's Avatar
Ive done plenty of radios in my car and never once had a problem. Just a word of advice your attenae(sp) is your ground. So there may not be one on the harness you get to plug in the stock one.
Old Jul 13, 2006 | 01:41 PM
LancerMarita's Avatar
In my installs (any car/ truck), I screw or bolt the ground wire into a metal part of the chassis.
mobman
12
Mar 7, 2010 12:23 PM
shuttlegoose
Feb 3, 2009 06:43 PM
JohnnyBoy427
Jun 10, 2007 08:10 AM
Eildydar
Apr 1, 2007 05:41 PM
xvii
Feb 14, 2007 12:05 PM
