View Poll Results: What do you think
I like It!
23
63.89%
Waste of time
8.33%
Not my style but i like it
8.33%
I would Buy one for my car!!
12
33.33%
Multiple Choice Poll. Voters: 36. You may not vote on this poll
Custom Fiberglass Trunk
Old Aug 29, 2006 | 07:05 AM
akunochi's Avatar
Not to hijack...I will do sub box trunk for approx...half the price of a shop + the cost of materials.
Hint to OP: When using fleece ensure it has a high polyester content this allows it to stretch easier and have a lower chance of wrinkles.
Old Aug 29, 2006 | 02:47 PM
sivs's Avatar
sweet
Old Aug 29, 2006 | 05:55 PM
LancerChicka84's Avatar
MORE UPDATES AND MORE PICTURES!!!
shows how close the trunk is to hinting but clears perfectly!!!
perfect fit in the front.. just need to sand the bottom a bit...
the entire enclosure in the trunk....
the enclosure with all the trim put back to check fitment.. again perfect..
Okay so i learn a few things today... when adding layers to the lining only add two to the back at most and the rest in the front, fitment is tight!! had to sand a few parts here and there... Also totally forgot about makign sure i could close the trunk, but the clearance is perfect almost like i plan it like that... but other then that i'm going to add some fiberglass in places that we feel need it and then use the bondo body fill to smooth everything out and sand!!! i think it looks amazing!! i'm soo shock how it turned out!!!
THANKS
Old Aug 29, 2006 | 06:26 PM
lancerman360's Avatar
Wow, that looks good. You going to paint it or just throw on some carpet? I vote for paint.
Old Aug 29, 2006 | 06:32 PM
Its definally getting painted without a doubt.. doing to paint it silver to match the car!! the floor will have black carpet with a plexi glass window in the back showing a amp and above that on an angle will be another amp... i cant wait!! hopefully will be finished by end of the month!! (september)
THANKS
Old Aug 29, 2006 | 08:32 PM
EnJaNir's Avatar
Looks great so far
Old Aug 29, 2006 | 08:39 PM
yellow04oz's Avatar
lookin good!
Old Aug 30, 2006 | 06:44 AM
crazy4ozs's Avatar
very nic eglass work...what kinda sub is going in there? amp rack?
Old Aug 30, 2006 | 06:55 PM
UPDATE:
okay well tonight i sanded part of the enclosure to make a better fit in the front.. I also added more layers of glass to it. This shoudl be the last of he glass and tommorrow i will check the box out check for any leaks and then drill the small hole and put the speaker wire in and seal it up.. After that comes time to do the "body work" to it and make it all pretty and smooth and then primer.. paint wont come until the rest of the trunk is finished. I'm also going to be starting the passenger side either tommorrow or friday!!
THANKS
Old Aug 31, 2006 | 06:18 AM
As far as subs and amps go, we have some visonik subs and amps laying around that we are going to use. There will be an amp rack installed in the back for the one amp and the other will be in the floor with a plexi glass window.. the floor will also have hinges so it will lift up to reveal the spare tire!!
Thanks
Old Aug 31, 2006 | 06:35 AM
TougeOZ_04's Avatar
i want one for the other side if you could make it, becuase that's where i'm going to put he meth inject system
Old Sep 1, 2006 | 06:16 PM
UPDATE:
i have added more fiberglass to the enclsoure to make it even stronger. tommorrow i will begin to do the body work and prep the enclsoure for paint. I will then be begining on the passenger side of the car!
Also if anyone else is interested in us making you some custom enclosures or linings please send me a message if you are serious about purchasing! Also if you would like one but cant cause of a rear strut bar no problem, we can create the opening for the strut bar in the enclosure and still make it look beatiful!!!
THANKS
Old Sep 2, 2006 | 08:47 AM
rain sucks... i want to do one more test fit before the body work but this damn storm is dumping to much rain for me to test fit it in my car... (damnit i need a bigger garage!!)
THANKS
Old Sep 2, 2006 | 12:40 PM
mrtrunks's Avatar
when the rain stops you should take some more pics I love how its coming out, giving me a lot of ideas.
Old Sep 2, 2006 | 02:33 PM
UPDATE
I manage to squeeze the *** end of my car in he garage between the wall and my trans am.. just enough to get it out of the rain and test fit the enclsoure after the lastest bit of glass work (i added a lip to make it match the top of the trunk so it looks molded into the trunk itself...) after this last bit of glass dries i'm starting the body work to it!! I'm really hoping to start it tommorrow where i will then post more new pictures! I really want to paint it but i'm waiting until i get the enire trunk finish before paint so i dont scratch any of it workign on the rest of the trunk!
THANKS
