Pushed my subs too hard?
Old May 23, 2003 | 06:26 AM
  #46
Joka's Avatar
my 200A alternator is a delco, it was around $450 and like $50 to install. the battery isolator was around 60-75 bucks. my 2nd battery is an SVR deep cycle, but an optima will work the same. i havent upgraded the battery under my hood, but i doubt your pulling the same current i am. Check out pep boys for the battery isolator.
Old May 23, 2003 | 10:48 AM
  #47
Higgity Hank's Avatar
In an ideal situation, you should use 2 of the exact same batteries. (same model, same date of manufacture, same useage age)
And adding a second batt won't do anything to help the car, unless you like to bump your system with the car off. In fact, you'll probably just make things worse. If your alt can't handle charging one batt and running an amp, throwing another load onto it isn't going to help.
I'd work on the new alt before I got more batts, etc. But upgrading the big 3 should be way up on the list. Far before new alts, more batts, caps whathaveyou.
Old May 23, 2003 | 12:08 PM
  #48
Zeeshan's Avatar
just a little off topic, but since we are talking about fuses...what amp fuse should i get for my setup? i have a....what claims to be a 1200watt pyramid amp (bs im sure, cuz its a cheap *** amp) and two infinity perfect 12.1's. i have a 40A fuse right now...is that fine? should i go higher?
Old May 23, 2003 | 12:13 PM
  #49
Iamkar33m's Avatar
What is the "big 3" that you are referring to upgrade?
Im a n00b, so bear with me here.
Old May 23, 2003 | 02:01 PM
  #50
Zeesh... how long have you had the 40a in there?
Have you ever blown it?
If the answers to those questions resemble "A while" and "No" then don't worry about it.
Old May 23, 2003 | 02:02 PM
  #51
And I completely forgot to mention that I'll be starting a new post explaining the big 3
(or maybe I'm just a postwhore too)
tiesto14
Aug 9, 2016 05:20 PM
SatsuMX
Lancer Troubleshooting
Feb 22, 2016 08:38 AM
Pssst
Feb 6, 2012 06:28 AM
Spooky_Neo
Jun 24, 2008 02:04 PM
bcustom152
Jul 28, 2002 05:21 PM
