View Poll Results: does your alarm need a trunk pin?
yes, i have a trunk pin/switch
50.00%
no, my alarm was wired properly
50.00%
Voters: 6. You may not vote on this poll
alarm question/poll - pls read
Old Jul 2, 2003 | 06:32 AM
llmask's Avatar
i just had my hornet 554t installed.
and i noticed that if i pop my trunk, the alarm doesn't go off.
my question is,
for the people with alarms, do you have a trunk switch (trunk pin)?
Old Jul 2, 2003 | 08:28 AM
think's Avatar
what do you mean? when you pop the trunk? from the remote or from the inside of your car? i dont have a trunk pin...i just tapped into the trunk light wire. that way, when the trunk has been opened, light goes on and alarm sirens.
Old Jul 2, 2003 | 11:21 PM
llmask's Avatar
so you ran a wire all the way to the back?
and what kind of alarm [do you have?
Old Jul 3, 2003 | 08:48 AM
think's Avatar
yea..i ran a wire along the bottom side moldings to the trunk. i have the fm-2009.
Old Jul 6, 2003 | 10:07 PM
nightrider's Avatar
jsut do wat i did. although my trunk is hooked up the same way with the light thing, just unhook the hook on the trunk so the only way to open it is with ur key.
Old Jul 12, 2003 | 02:56 PM
Dr Crash's Avatar
instead of running a wire all the way to the back, you could just look for the wire in the driver kick panel, that's where it usually runs. i can tell EXACTLY where it is in a couple days when i install my alarm or you can find the colour at the light in the trunk and search for the same colour in the kick panel. don't go probing randon wires though, make sure you have a multimeter or protected probe like an "auto-probe" brand to check the wire. this way you can't screw anything up
Old Jul 16, 2003 | 08:00 PM
llmask's Avatar
did you find that wire yet? i really want to avoid running the wires to the back.
Old Jul 18, 2003 | 04:42 PM
hitman007's Avatar
Registered User
12volts white + ignition harness
Starter black/yellow + ignition harness
Ignition black/white + ignition harness
Accessory blue/black + ignition harness
Second Accessory blue/white + ignition harness
Keysense blue ignition harness
Power Lock purple - driver kick, door harness
Power Unlock lt. green - driver kick, door harness
Lock Motor blue/red 5wi driver kick, door harness
Unlock Motor white 5wi driver kick, door harness
Parking Lights + grn/yel (L), grn/wht (R) + wht plug bottom of fuse box
Hazards white - hazard switch
Turn Signal(L) lt. green or white/blue + driver kick, harness to rear
Turn Signal(R) yellow + driver kick, harness to rear
Reverse Light brown + driver kick, harness to rear
Door Trigger white - wht plug bottom of fuse box
Trunk/Hatch Pin green/orange - light in trunk
Factory Alarm Disarm gray - driver kick, door harness
Disarm No Unlock N/A
Tachometer black/yellow or black/green ac either ignition coil
Brake Wire green + brake pedal switch
Parking Brake blue/red - parking brake switch
Horn Trigger blue/red or red - steering column
Use at your own risk!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 22, 2003 | 01:00 PM
think's Avatar
Old Aug 10, 2003 | 10:55 PM
llmask's Avatar
hey hitman, that trunk wire, is that on the front of the caR?? where is the location?
Old Aug 13, 2003 | 09:50 PM
Mr anonymous's Avatar
I grabbed it at the light, but I also ran the wires for a trunk release solenoid. I found it easier to grab it there then to prob around wires in the front.
TxFAkuma
Apr 28, 2016 04:57 PM
jnick
16
Jun 30, 2015 03:35 PM
Outlandersprt13
Outlander Sport
Dec 31, 2014 07:43 AM
evo72man
Mar 12, 2008 08:56 PM
superfly78209
18
Nov 30, 2006 12:56 PM
