Ita almost all here
Old Nov 22, 2008 | 08:00 AM
surfalex1's Avatar
Ita almost all here
Everthing is starting to show up will get pics up when they do
(x)trunk dynamat
(x) Memphis Bell MC5.1400
(x) JL Audio 10" W7
(x) Memphis M Class Seperates
( ) Kenwood ddx 712
( ) PAC SWI-Jack
( ) Stinger Red Voltage Display
(x) Stinger SPC5010
( ) Optima Battery
(x) Audio Enhancers Ported W7 Specific Driver
Old Nov 28, 2008 | 06:58 AM
surfalex1's Avatar
kenwood ddx712
does anybody know what the baby blue wire on the metra harness does?
Or what color the steering wheel control is?
Old Nov 29, 2008 | 06:39 AM
surfalex1's Avatar
Well I am starting to tear into the car and have found that the rear speakers in the 09 (not sure about the 08) use a twist and lock feature if you take and draw a line on the outside of the tabs in the doors it makes a perfect circle. You will need a good air saw with a short blade or some nice tin snips to cut out the sheet metal. i had to put a trim ring down to raise the speaker because the depth hit the brace for the door. The magnets on the MCSYNC 6.5 where too big. You could probably trim the door and fit 5.25 in there if you wanted. There is also plenty of room to rivet your crossovers inside the door and clear the window when its down.
Old Nov 30, 2008 | 01:03 PM
surfalex1's Avatar
I go the steering wheel control hooked up. I used the PAC SWI-JACK it wasnt too hard too hook up. The diagram I got was backwards but after checking with the volt meter I got it done. I tapped the white wire into the blue wire on the mits side of the speaker harness and then made a ground wire to ground out the black wire. Put the PAC on selection 3 for kenwood and then programed it to 8 and taught it the buttons.
Old Dec 2, 2008 | 12:38 PM
surfalex1's Avatar
Old Jan 14, 2009 | 08:32 PM
yitzac1990's Avatar
personally, im not a big fan of Memphis, but DAMN that all looks good man!!! keep posting!
Old Jan 26, 2009 | 02:02 AM
nawgee's Avatar
(chills) im loving the setup so far bro!!
MORE PICS!!
Brownie614
09+ Ralliart Show and Shine
34
Jul 15, 2013 09:18 AM
Webman
105
Feb 4, 2013 07:23 PM
cij911
West Region
Jul 14, 2008 08:00 PM
dbsears
Northwest Region
Jul 15, 2007 03:40 PM
davids2004
Jul 28, 2006 02:27 PM
