12 volt noise filter
Old Feb 19, 2009 | 06:44 AM
shinbumee's Avatar
has anybody installed noise filter to the amp?
not with RCA wires but with just black and red wires..
im trying to install because I hear a high pitch buzzing sound when the car is on.
I took my car to the audio place and they want $65 for checking and seeing what the problem is, i don't want to spend that much money for this.
it's not the one with getting louder with acceleration but the sound is still and annoys my ear.
I tried to sand the ground again and separate the power cable with speaker cables but still did not work.. hmm
anybody?
Old Feb 19, 2009 | 07:12 AM
lancer0220's Avatar
try a ground loop isolator ? i think they are like 15 bucks , you can probably buy one try it and if it doesnt solve the problem take it back.
Old Feb 20, 2009 | 08:58 PM
shinbumee's Avatar
i will try some
but i have a 5 channel amplifier which has 6 different RCA inputs from the headunit.
so do I have to buy 3 of the isolators?
Old Feb 20, 2009 | 09:00 PM
Evodreamer28's Avatar
Did you run the power wire and rca's on the same side of the car?
Old Feb 20, 2009 | 09:13 PM
shinbumee's Avatar
no, that's the problem that I've fixed long time ago.
the sound hurts my ear..
I looked some online and installing it near the amplifier would eliminate the noise.
there are 6 rca outputs on my amp/headunit. 3 pairs of rca cables runs through from headunit to the amp. so.. do i have to get 3 of the isolator? or would one fix everything?
I grounded the ground wire to proper place, grounded all the paints off, and used short length of ground wire.
Old Feb 22, 2009 | 10:46 AM
Lucas03ES's Avatar
Is the noise coming out of every speaker that is amped, or just a certain single speaker or a pair of speakers?
Old Feb 22, 2009 | 01:07 PM
shinbumee's Avatar
I installed one ground loop isolator and the sound is almost gone.
I have 5 channel but I only used one.
but I still hear a little bit of noise not like before.
I saw some people online who installed 2 isolators for 4 channel speaker amp.
So I would like to try another one later.
sblas
Lancer How Tos / Installations
Nov 1, 2015 04:31 PM
delkat
31
Apr 17, 2013 04:01 AM
smoOVE
Feb 17, 2013 06:49 AM
bskidmore6698
Jan 20, 2009 12:19 AM
EVOclub4
12
Jul 8, 2008 04:43 PM
