How to get tweeters working again?
Old Oct 10, 2003 | 03:52 PM
datdjrobp's Avatar
from what i've seen of infinity pics, when you hold your speakers up to where the stock ones are the speakers overall diameter isn't as large as the hole you're trying to put it into so the holes can't match up.
you'll need something to screw the speaker into that is wide enough to also put screws in that will go into the factory holes.
Old Oct 10, 2003 | 10:39 PM
thuan's Avatar
What you can do is used the factory speaker as mounts for your new ones.
Cut the plastic spider that is holding the magnet and papper cone out. You can break them off or saw them off. You will have be left with a allmost perfect hole that wil fit the new speakers . If you need pixs i can post some pix for you in the morning..
Old Oct 11, 2003 | 11:12 AM
rebelzx's Avatar
Post that **** up!
Old Oct 11, 2003 | 11:41 AM
thuan's Avatar
Here ya go Reb. This shuold give you and other the idea of what im trying to talk about, Home made mounts
befor
after
White_KnightOZ
Nov 23, 2008 03:49 AM
Noize
22
Apr 18, 2008 11:15 PM
livelyjay
15
Aug 20, 2004 08:42 AM
gabrielg
Oct 5, 2002 04:14 AM
bcustom152
13
Sep 17, 2002 07:26 AM
