Installing a deck (ground wire Q)
Old May 3, 2004 | 06:09 PM
royalflush313's Avatar
Hey,
im going to install a deck in the lancer, and I just wanted to know where the best spot would be to place the ground wire.
And also when I'm installing the deck, I don't have to bother taking off the negative terminal of the battery do I?
thanks in advance
Old May 3, 2004 | 06:28 PM
could I just put a ring terminal on the ground wire and attach it to some metal screws in the back of the dash???
Old May 3, 2004 | 06:29 PM
bobaab's Avatar
try it..im sure u can find a screw that is touching a part of the chassis
Old May 3, 2004 | 06:34 PM
try it eh... Im looking for a little more confidence haha
I don't wanna end up with blown fuses somewhere
Old May 3, 2004 | 06:36 PM
petey pab's Avatar
you should disconnect the battery if youre doing anything electrical. and a metal spot behind the dash will work fine for a ground.
Old May 3, 2004 | 06:37 PM
alrite, I will do that. Thanks!
Old May 3, 2004 | 06:41 PM
bobaab's Avatar
u know why i can't give u a straight answer? i never used the ground wire coming from my headunit..it's really, really, really weird. it works tho..i guess.
Old May 3, 2004 | 06:44 PM
I guess the headunit casing is metal, and the gide rail thing is also metal, so its ok? But that doesn't really make much sense, but as long as it works, its all good
Old May 3, 2004 | 06:45 PM
2ggst's Avatar
since the radio is bolted on to the brackets, and you're screwing it into the car wh ich is metal, the radio grounds itself. you don't have to ground the wire but if you wanted to, the bolt on the back of the dash will do fine.
Charlie-Y
22
May 4, 2022 03:56 AM
dmakins
Mar 7, 2014 02:35 PM
porkchop87
Toronto Lancer Club
Sep 2, 2012 04:16 PM
o6RSEvo
Nov 4, 2006 08:18 AM
2BARevo
15
Sep 24, 2005 01:11 PM
