Road/Race Piggy-Back Evaluation
Old Aug 6, 2007 | 10:42 AM
  #46
Rabidhamster's Avatar
Originally Posted by CamShaft
Well, the trucks I work on have up to 11 ECU's all talking to each other.
If the engine ecu is anything like our it will be able to tell you a lot more than just freeze frames when faults are stored. The freeze frames are just used to diagnose an inactive fault that has had a fair many counts.
The ecu and dealer software can do a lot more, unless you work at mitsu, i would be wary of readily waiving a 10 year warranty.
To be honest i dont even like the wiring. Unless you paste it up with some grote electrical grease. If you want go ahead and tape it up...it even traps the moisture more that without.
I just can't put myself to possibly voiding my warranty with and extra 10-15 ponies....
yeah most auto ecu's aren't as 'advanced' as the truck ecu systems.. the marine systems are similar to the trucks they record everything. the majority of auto ecu's only record when a fault is tripped. and even then they are looking for out of spec parameters, where the piggy's can only stay within oem ecu spec.
the ecu's your talking about are used in situation where the vehicle is gonna get BEAT on and they need to know EXACTLY what is going on... trucks, exotics, marine.
as for warranty voiding... its the name of the game with modding. I fully understand that people don't want to risk it. I however... have a 100hp of nitrous in mind
Old Aug 6, 2007 | 04:47 PM
  #47
madfast's Avatar
Originally Posted by SeRious08
Hmmm. I just went to the dealership and talked over with the techs. They said that the piggy "WOULD NOT" void my warranty. He hooked up an ECU scanner and he said it didn't flash anything out of the norm.
unless this is specified in writing i'd take that with a grain of salt. wait until you try to fix it if it ever blows and they'll be like "hey aren't you the guy that had the piggy, etc. yeah you voided the warranty cuz it caused such and such. as you can see here in this obscure and ambiguously worded sentence in the warranty if you so much as touch the engine you void the warranty. you see we strive to make money and we want your money so anything that you do that isn't done by us will void the warranty...."
call me cynical but not all places are mod friendly, especially if there's money to be made. if you ever need the warranty just hope they're good on their word....
Old Aug 6, 2007 | 07:51 PM
  #48
2008BLACKGTS's Avatar
If there is no physical evidence you should just be able to unplug the battery and let the ECU go back to its factory settings and wipe out the fuel trims.
Old Aug 6, 2007 | 09:29 PM
  #49
heres the other thing some people don't realize..
the dealership makes money on warranty claims... they charge the manufact. they don't care cause either way they get money. HOWEVER... the manufact may turn around and deny the claim they send in .. that is usually the only reason you get a little wiggy with the dealer.. they just want to make sure they get their money. most of the time if it's a lil twiggy, but you've been at the dealer for everything maint wise and spent your money, they will play with the wording of your claim to get the warranty work
Old Aug 6, 2007 | 10:35 PM
  #50
ROCK's Avatar
I am not surprised as far as the dealer thing goes. It is solid. I have a ton of miles on the piggy and pulley now. I drive a 2008 everyday for 6 months now.
ROAD/RACE
Old Aug 6, 2007 | 11:14 PM
  #51
CamShaft's Avatar
This could be quite true as I don't work automotive....as for the guy who said the dealership wouldn't void warranty for a piggyback is interesting... I am going to go to my dealer tmw, in canada. I am going to get a lot of info as per warranty stuff and will try and post it tmw night or the next day.
Not saying the piggyback is bad at all...i would love to have it but I bought a new car so i didn't have to work on it...so I like warranty LOL
Just for curiosity sake, have you dyno'd the lancer with the piggyback/intake and exhaust?? how much is it putting out after that ROCK?
Old Aug 6, 2007 | 11:20 PM
  #52
CamShaft's Avatar
Just curious....but truck ecu's have back up batteries for the computers, you can disconnect the batter and it will still store info...don't know if automotive has the same thing or not....I thought the automotive industry was way ahead of semi-trucks, but I guess we surpassed a few years back... at least I know why I get paid more than being an auto mekanik now :P
Old Aug 7, 2007 | 11:05 AM
  #53
Blacksheepdj's Avatar
Yeah, cars have done that for years.
Old Aug 7, 2007 | 06:21 PM
  #54
Are these batteries or capacitors? I would think that an internal battery would be a maintenance issue.
Old Aug 7, 2007 | 07:01 PM
  #55
No clue.
Old Aug 11, 2007 | 09:57 PM
  #56
otter's Avatar
EvoM Administrator
I see some misinformation in here. A piggyback doesn't modify anything in the ECU. It merely sends the ECU false signals and the ECU acts appropriate for the signals it's getting. A tech, even with the MUT computer, will not be able to tell if a piggyback was installed unless they actually see the wire splices.
Old Aug 12, 2007 | 12:40 AM
  #57
CamShaft's Avatar
in that case run the wires down and hide 'em deep
Old Aug 12, 2007 | 12:28 PM
  #58
Nothing programmed into the ECU, however, the ECU will adjust its trims and so on and so forth based on the false signals that it is getting from the PiggyBack. I good tech should be able to tell.
Old Aug 13, 2007 | 12:32 AM
  #59
polar1120's Avatar
Well when I went to the dealer to get my inspection light turned out the tech never found anything and I have the piggyback installed. So maybe I'm just lucky or I had a bad tech maybe?
Old Aug 13, 2007 | 07:23 AM
  #60
Little bit of both. The car is brand new, so he probably didn't think to hunt for mods yet. Although I'm amazed at your mod list, BTW.
Most techs aren't the smartest in the world. I've met some at my local dealership that didn't seem to know jack s**t. So it's perfectly possible that he didn't notice it. Or he didn't think the problem related to a piggyback so he didn't look. Etc.
