Someone please help me with Ecuflash
Old Sep 6, 2008 | 02:02 PM
ThunderOZ's Avatar
It's not reading my car right. My ROM ID is 88560021 but it doesn't pick it up right. Here's what I see.
Old Sep 6, 2008 | 02:12 PM
ThunderOZ's Avatar
Here's my file http://www.box.net/shared/1g1qgupamu
Old Sep 7, 2008 | 10:21 AM
ThunderOZ's Avatar
up
Old Sep 7, 2008 | 07:05 PM
ThunderOZ's Avatar
please
Old Sep 8, 2008 | 07:50 AM
nestoledo's Avatar
enjoy!
File Type: zip
Old Sep 8, 2008 | 06:58 PM
ThunderOZ's Avatar
didn't work... I see the same thing as in the original picture...
Old Sep 8, 2008 | 08:18 PM
nestoledo's Avatar
Download the latest version of EcuFlash. here http://openecu.org/index.php?title=EcuFlash
save the 88560021.XML in Program Files/OpenECU/EcuFlash/Mitsubishi/Lancer/rommetadata
Leave only, 92290022, 98720010, lanceratbase, and 88560021 XML files. Close the folder...
try it, if x and y axis are not correct, follow these link
https://www.evolutionm.net/forums/sh...d.php?t=357840
the definition are work fine
Old Sep 8, 2008 | 08:32 PM
ThunderOZ's Avatar
ok I'll go try it now...
Old Sep 8, 2008 | 09:12 PM
ThunderOZ's Avatar
Same thing as the first pic... No tables... Is there a way to reset ecuflash or something. I think when I first used it I tried to make a def file and I may be stuck on that...
Old Sep 9, 2008 | 06:19 AM
nestoledo's Avatar
try it download EcuFlash 1.29a here http://www.box.net/shared/20sp04nxhu
maybe do not can read the ROM with these version, but you can edit your maps and load with the newest version
does not forget save the file xml in rommedata
Here is your maps
Old Sep 9, 2008 | 11:09 AM
ThunderOZ's Avatar
Ok I think I may have screwed something up then b/c it still isn't loading everything right...
Old Sep 9, 2008 | 11:27 AM
nestoledo's Avatar
i think no, try uninstall and re install EcuFlash but be sure to erase all old folder
sorry i can not help you, but i am from other country and i can not speak english, but your problem is your pc
Old Sep 9, 2008 | 12:08 PM
ThunderOZ's Avatar
Hey you've been doing pretty well so far I'll try using my other laptop too then...
Old Sep 9, 2008 | 12:23 PM
nestoledo's Avatar
thank you
ok, good luck
Old Sep 9, 2008 | 12:35 PM
ThunderOZ's Avatar
I think the problem is when I first started using ecuflash, I tried to make my own def file and I think it's stuck on that point.
