Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old Aug 21, 2012 | 01:42 PM
  #691
RoadSpike's Avatar
Originally Posted by HornstarBU
Think I see my problem...bad MAP sensor.
holy **** man thats a crazy *** jump!
Old Apr 18, 2017 | 04:03 PM
  #692
Alchem1st's Avatar
This may be an ancient post; but I'd like to add some info here. I'm running a fully built 2.3 stroker 4G63 on a Lancer ECU and can confirm that there is no circuitry for a boost control solenoid. Took ages to figure that out lol. Also, I'm running on speed density using the Phenem 9417 rom and while it all is working; I'm not getting a consistent reading from the o2 sensor (which is new OEM) and I tend to think it may also be an issue related to running this ECU. All this said; it's not a bad ECU to start a build with. Just know that you may experience these issues.
Old Nov 20, 2020 | 02:31 AM
  #693
Dhanis Egan's Avatar
hey my car is also 05 lancer es AT. how did you change the rom id and updated the firmware. Thank you
Old Nov 20, 2020 | 05:25 AM
  #694
Evo at roms on at lancer???
okay so i cant shake this on my mind. And i really want to try this.
My car is 2004 Lancer ES AT with MH8306F written on the ECU and SH7055 Memory Model which is exactly the same as an EVO 7 2002 also AT
whats the worst that would happend if my curiosity can't hold it and flash the evo 7 rom to my ECU?
It both have the same memory model and they are both automatic transmission
Old Nov 23, 2020 | 10:18 AM
  #695
Rovin Raj's Avatar
why would you wanna try evo 7 Rom when roadspike already prepared a lancer rom with full xml play with.
Old Feb 9, 2021 | 07:14 AM
  #696
because there is no definition file for my rom
Old Feb 9, 2021 | 07:15 AM
  #697
because there is no definition file for my ROM
File Type: bin
Old Feb 18, 2021 | 12:15 AM
  #698
gcvalenz01's Avatar
I was able to modify the 05 Lancer definition file to work with your rom. Had to do that to get to modifying my 06 rom. It looks like it's all mostly there. I'm just a newb so if anyone else would like to chime in to check on this feel free. Anyway hope this helps some
File Type: xml
Old Feb 18, 2021 | 12:39 AM
  #699
OMG thank you so much but all the reading is wrong i think. can you teach me some more? hit me up on whatsapp +62811186665
Old Apr 2, 2021 | 01:57 AM
  #700
Rovin Raj's Avatar
did you get it sorted?
Old May 8, 2021 | 10:57 AM
  #701
gcvalenz01's Avatar
Hey I know it's been a while but I have finally maybe defined your ROM a bit. I've only got the fuel and timing maps so far. I will continue to work on it. Before you make any edits, log and make sure these maps make sense compared to your logs then try and make small edits to see how to takes it. let me know how it goes.
File Type: xml
Old Jan 7, 2022 | 01:54 PM
  #702
Alex1101's Avatar
I can make a more detailed description. The motor I understand 1.8?
Old Jan 7, 2022 | 01:57 PM
  #703
Alex1101's Avatar
Guys, who rides the tephra mod, how much is the maximum load? for some reason, when the throttle is fully open, it reaches 120-130. I transferred all maf cards from the native firmware
Old Dec 5, 2022 | 02:44 AM
  #704
tonet_project's Avatar
Question
how you do that ?
can you teach me how ?
senate6268
Lancer Engine Management / Tuning Forums
272
Jun 25, 2024 08:27 AM
infiniumz
10
Jun 17, 2021 01:54 AM
JKX
Jul 23, 2014 02:21 PM
RoadSpike
Mar 17, 2011 02:03 PM
