Community Tephra Tweaking
Old Apr 6, 2011 | 01:29 PM
  #946
RoadSpike's Avatar
Originally Posted by Mitsu.kid.02
STILL slacking... been so busy with other work :-/ hows the tuning coming?? any suggestions for what i first flash this?
I really haven't heard back on my last change so I'm not sure
Old Apr 6, 2011 | 02:17 PM
  #947
Mitsu.kid.02's Avatar
Link stop slakin too!!
Old Apr 7, 2011 | 04:16 PM
  #948
4g94T's Avatar
For those wanting to disable the EGR, you might need to also set FAA bit 9 to 0.
For the past weeks, I've had lean AFR swings and low RPM dips while coming to a stop.
This caused the car to idle rough and want to die for a second or two and then bounce back up to idling normal again.
This only occurs when the car is not in operating temp.
I disabled ignition warm up since Im catless and been problem free since then.
I noticed some Evos have this problem, might work for you also.
Old Apr 12, 2011 | 10:05 AM
  #949
Any updates Link/ RS?
Old Apr 12, 2011 | 03:51 PM
  #950
RoadSpike's Avatar
I haven't heard anything I would just try the rom I posted if thats your plan to test
Old Apr 13, 2011 | 10:31 AM
  #951
K will do!
Old Apr 14, 2011 | 11:51 AM
  #952
What happens when i throw i bigger cam in the car, like a stage 3 or 4 RPW cam, does this mess w/ speed density?
Old Apr 14, 2011 | 01:27 PM
  #953
RoadSpike's Avatar
VE will change and you'll need to adjust that table to suit the new VE. It shouldn't go off by any crazy amount so it should be straight forward and tunable.
Old Apr 14, 2011 | 05:21 PM
  #954
link62's Avatar
been running good just need to adjust the cruise afrs on the free way cause my mpg gone down a bit cause im driving at 13 afr but other then that only prob i got to worry aobut now is my tranny is gonna crap out on me soon cause i cant drive more then 50 and accel with out the car shaking violenty lol
Old Apr 15, 2011 | 06:56 AM
  #955
HornstarBU's Avatar
Uh...my car does vibrate some when significant power is applied to the wheels, but I thought it was just cause it all started when I "stiffened" my motor mounts. How/what happens to make the tranny need to be replaced, and is that shake like, a tell-tale sign? or ...gah, now I'm scared.
Old Apr 15, 2011 | 08:27 AM
  #956
This problem can be "tunned out" in the "vibration vs. road" table in your ROM.
Most of the time when shakin occurs its because the wheels are out of balance.. never herd of a trans prob shakin the car?
Old Apr 15, 2011 | 09:43 AM
  #957
link62's Avatar
had the wheels balanced and still does it bad, i do notice it does a lil bit a squeling going slow but when im cruising in my neighborhood i let the rpm go to 1k then i push on the throttle easy and u can hear the car clank as it trys to accel
i also did a test where i put the car in 2 and drove and let the engine slow me down and as the rpm went down u can here the tranny clank while it does it and my mounts are filled also and it just started doing this recently so imagine driving down the road and the cars vibrating a lil and then when u start to accel it turn into a 11.0 earthquake in the car and then when i ease off the throttle it will stop shaking.
i can try to get a vid of it with my gopro so you can see how bad the camera will shake haha
Old Apr 15, 2011 | 12:52 PM
  #958
RoadSpike's Avatar
any idea if this is happening because of the SD patch? I can't imagine but better safe than sorry.
Old Apr 15, 2011 | 07:24 PM
  #959
4g94T's Avatar
Will SD allow ITBs? A high compression, high revving, E85 NA lancer would be nice
Old Apr 15, 2011 | 08:03 PM
  #960
RoadSpike's Avatar
Yes but you would need something for the map sensor to work off of remember its speed density not alpha N which is more of a ITB setup.
What SD needs is a vacuum line behind the ITB plate probably all 4 of them tied into one line for a good average.
If the car was to be tuned Alpha-N style the whole system would need to be reworked.
