my oz keeps stalling!! help me please!!!
Old Oct 15, 2011 | 07:05 PM
2002lancer.oz:('s Avatar
just got the turbo on. stalls when i hit the clutch fast and or break. does not do it as much anymore but still stalls. anyone else have this problem?
Old Oct 16, 2011 | 12:05 AM
03lances's Avatar
Thats a pretty open question there we need some more info. Turbo kit off shelf or custom? stock or aftermarket injectors? Maf stock? What are you using for tuning? Could be a number of different possiblilties
Old Oct 16, 2011 | 04:15 PM
ebay t3t4 turbo..running it with a fmu. stock injectors did it alot before. not as much now but still doing it. just wanna get it fixed (
Old Oct 16, 2011 | 04:57 PM
jakermeister's Avatar
Your bov recirculated??
Old Oct 17, 2011 | 03:15 AM
there was a vac leak comming from the bov. we used silicon to seal it. i think my waste gate has a little leak but i dont know if its enough to make my car stall like that
Old Oct 18, 2011 | 08:50 AM
FiReTRuCKoZ's Avatar
if you aren't recirculating your BOV, it will stall every time.
Old Oct 19, 2011 | 02:56 AM
yea its deff. recirculating. i dont know what else to try though
Old Oct 29, 2011 | 02:08 PM
MurphDurph's Avatar
what fuel pump are you using?
Old Oct 29, 2011 | 02:14 PM
HornstarBU's Avatar
When you say "did it a lot before", you mean pre-turbo? My bet is a gunked up ISCV sensor or whatever it's called, or maybe you turned your BISS screw, or possibly you have a dirty throttle body? Or maybe the MAF is dirty?
you have a wideband?
Old Jan 24, 2012 | 04:40 PM
02modlanceroz's Avatar
are you throwing any engine codes? i had the same problem when i installed my turbo-kit. i had a piggyback installed before and when i installed the rrm kit, it came with a different piggyback. here, on the original piggyback there was a wire for the MAF that you cut and it goes thru the piggyback to change the ohms. when i installed the new piggyback i forgot that i had to cut that wire, so all i did was solder the wires to the color coded ones i had, and taped off the ones it didn't use. so basically my MAF wasn't hooked up to the ecu. hooked the wire back together, reset ecu, problem fixed. it should be in rrm's instructions for just incase. i called them, and they had no idea what i was talking about
Old Jan 26, 2012 | 09:04 PM
*02Lancer*'s Avatar
More info updates? Codes? Get to the AutoZone if you have to. Codes would help a lot. Also an answer to the'' did it do it pre-turbo'' And do you have aftermarket mods like lightweight pulleys flywheel. Cause my car would die every now and then when I push in the clutch due to not enough mass to keep its rotation going
Old Jan 28, 2012 | 09:00 AM
eusgen's Avatar
My car stall occasionally on hard brakes or just general braking when coming to a stop. I have a lean code that comes and goes, could this be a leak somewhere?
Old Jan 29, 2012 | 06:56 AM
Well when I got my turbo it was only set to 6 psi I didn't change or flash the Ecu.. If I did that
Do you think that had anything to do with it. And it still does it i just learned to drive it. Help me!
Old Jan 29, 2012 | 07:05 AM
slatermvp's Avatar
still not enough info but try cleaning the MAF and throttle body. Do you have to rev it to keep it from dieing?? battery volts dropping??
Old Jan 29, 2012 | 08:13 AM
CrAnSwIcK's Avatar
how are you fuelling? what kind of injectors are you using?
Thirddead3
Lancer Troubleshooting
Jul 5, 2017 08:49 PM
mnewdigate
10
Apr 24, 2016 11:25 AM
bspsrt-4
May 26, 2007 05:05 AM
White OZ Rally
Sep 6, 2006 08:20 AM
MikeKondilis
Southeast Region
Jun 4, 2006 10:01 AM
