OZ Help!
Old Jun 12, 2012 | 09:38 AM
73DatsunZ's Avatar
You could always go the cost effective route and put a 50-60 shot on the car.
There is something to be said about a cleanly installed wet nitrous kit. I had a B16 in an integra I owned a few years ago with a cleanly set up ZEX kit, and it worked very very well.
Old Jun 12, 2012 | 09:43 AM
ryancb's Avatar
Uh no....but when you do that let me know how it works out for you at least on the lancers 4g94...
Old Jun 12, 2012 | 10:27 AM
73DatsunZ's Avatar
?? I dunno if that was directed at me?? If people are turbocharging a stock lancer engine and making 200+whp... Nitrous is just as safe if installed properly.
Old Jun 12, 2012 | 11:12 AM
Green_Bandit's Avatar
Says who?
Old Jun 12, 2012 | 11:29 AM
73DatsunZ's Avatar
I assume you dont know how Nitrous works?
When nitrous oxide is used the nitrogen and oxygen split, making more oxygen available during combustion. A "wet" kit means that there is a Nitrous solenoid, and an addition fuel solenoid in the injection point to compensate for the additional oxygen coming in. ALSO when nitrous vaporizes, it cools the intake air temperature drastically which we all know makes the the air more dense, meaning more oxygen, meaning more combustion.
Old Jun 12, 2012 | 11:32 AM
ambystom01's Avatar
When nitrous oxide is used the nitrogen and oxygen split, making more oxygen available during combustion. A "wet" kit means that there is a Nitrous solenoid, and an addition fuel solenoid in the injection point to compensate for the additional fuel. ALSO when nitrous vaporizes, it cools the intake air temperature drastically which we all know makes the the air more dense, meaning more oxygen, meaning more combustion.
Thanks for assuming people who have been on this forum longer than you have are idiots . Nitrous on a Lancer is a bad idea. This is well known at this point.
Old Jun 12, 2012 | 12:05 PM
73DatsunZ's Avatar
... I didn't assume anyone on here was an idiot...
Just that they may not know how nitrous works thats all. If a stock lancer engine can handle 200+ whp from a turbocharger, is there something internally in the engine that just doesnt take nitrous well?
I have had experience with nitrous, and Ive never heard of an engine that can take turbo abuse not being able to handle nitrous?
Old Jun 12, 2012 | 12:20 PM
ambystom01's Avatar
Of course you did, you took it upon yourself to explain how nitrous works, as if people had no knowledge of it .
Part of the problem with nitrous is the heat and the violent hit of the power. It isn't like a turbocharger that builds somewhat gradually. Even with a turbocharger, you are limited in how much power you can run on the stock block. Most people start swapping out the internals around the 200 whp mark, if not out of necessity, out of safety.
Old Jun 12, 2012 | 05:47 PM
03lances's Avatar
Originally Posted by CrAnSwIcK
nice, right now i'm only running 8psi on a 14b, and made 213whp on a mustang dyno, the nice thing is that increasing boost is almost free That and i'm swapping the compressor wheel and housing for that of a big 16g which will make more power with the same amount of boost, but i would like to go for 10 maybe 12 pounds of boost.
I also built my own kit and used a lot of second hand parts...with tuning was about $2,000 just the parts was just over $1,500...
Second hand is the way to go unless your rich . I figured for my initial setup was about $2250 and that included gauges, clutch, injectors, full exhaust and of course the turbo components.
Old Jun 12, 2012 | 05:50 PM
03lances's Avatar
+1 I am just waiting to hear that unsettling boom lol. I have a spare vehicle though so if I did blow my engine no big deal just drive the other rig for awhile why I get another engine and build it .
Old Jun 16, 2012 | 12:07 PM
neil828's Avatar
Were is a good place to find a good turbo??
Old Jun 16, 2012 | 12:37 PM
Seifer780's Avatar
Use the search function. https://www.evolutionm.net/forums/la...ncbs-turn.html
If you go under Lancer Aftermarket Forced Induction *coughTURBOcough*, you will find all the information you need.
Old Aug 3, 2012 | 05:32 PM
coollol123's Avatar
Like These guys said, TURBO. But, if your like me and have little money to spend then go with a Cold Air Intake, Headers, Custom Exhaust, maybe some Cams. That's all I can think about..
BlackEvoV
Dec 17, 2014 11:54 AM
talwelsh
Oct 10, 2013 07:43 PM
Mexamilian
Lancer Engine Tech
67
Feb 8, 2011 02:25 AM
billsif
Aug 16, 2006 06:25 PM
mrauqinas
Canadian Forum
Jul 25, 2004 05:44 PM
