Alternator charge maps
Im looking for a way to display the alternator charge maps in the tephra v7 94170715
I have done some searching and have found only one thread talking about it and it only helped so much: https://www.evolutionm.net/forums/ec...rrent-map.html
What i dont understand is how do i change the xml to display the tables. I tried adding tables to the read template but no matter what i did i couldn't get anything to show up in ECUFLASH.
The main reason i want this feature is because i am running a lot of electronics... amps, gauges, radar, chargers...etc and at idle if i even turn on the lights it dips the idle for a second. When i try to roll down more then one window it dips down to 600 and takes forever.
Im also unsure whether or not the charge maps are different for the evo and lancer and how i would go about finding the factory lancer charge map. All im looking to do is up the output a little at idle.
any insight would be helpful. thank you
scheides
Oct 22, 2021 08:59 AM
