need help with defintion file 92290022
Old Dec 19, 2015 | 06:14 AM
thndrballl's Avatar
I have an 04 lancer es mt. the rom id is 92290022. the def file that is in the master definition isn't complete. when i bring up my rom all areas are grey. Yes i set to developer lvl. when i check maf or any other map it says "The current map description is invalid or imcomplete. Please edit the map description to fix the problem and the map will be viewable again."
I am positive the rom id is correct. i work at a mitsu dealer and used the medic to double check rom id. The only other wierd thing is the rom says 04 oz mt. I drive a 04 es mt.
if anyone could help i would be forever in their debt.
Old Dec 19, 2015 | 08:10 AM
02modlanceroz's Avatar
https://www.evolutionm.net/forums/la...ster-list.html
The rom you mentioned is for a 04 oz. But it wouldn't matter. You could flash a lot of Roms onto your Ecu. I'm running an Evo 8 on my 02 oz. So try the definition file from this site. Should give you better results
Old Dec 19, 2015 | 09:08 AM
thndrballl's Avatar
the def file im using is from this site. if i run a evo rom will the car run? the tables will be way off right? im trying to get my tables so i can run the teph rom
Old Dec 19, 2015 | 01:03 PM
Yes it would would work. You would have to adjust the MAF scaling and the injector scaling to match what you're running. You would also have to disable the immobilizer or have it match your stock rom. So don't flash a different rom to your car without backing up your original rom.
Are you running a turbo or are you just tuning a NA setup?
Old Dec 21, 2015 | 06:14 AM
thndrballl's Avatar
Im just tunning the na right now to get the hang of tuning. Ive started to piece together a evo8 turbo set up to turbo later.
Old Dec 31, 2015 | 01:15 PM
thndrballl's Avatar
Fixed
Found a fix. Used rom 91860016 and xml. Seems to work fine will test more.
thndrballl
Dec 30, 2015 09:34 AM
mcknight
Jun 1, 2013 04:22 PM
Aby@MIL.SPEC
AEM EMS
Feb 27, 2006 03:15 PM
MNGSX
AEM EMS
Jan 31, 2004 08:05 AM
