Seeking XML Definition for Lancer 2.0 ROM 53230006 (CVT to 5MT Swap - Driver Demand/T
Old Feb 23, 2026 | 07:16 PM
Coqueto's Avatar
Hi everyone,
I'm reaching out to the community because I've recently completed a CVT to 5MT (Manual) swap on a 2009 Mitsubishi Lancer 2.0 (USDM/Non-Turbo).
The car is currently running on ROM ID 53230006, which inherits from 52700006. While the car starts and drives, I'm hitting the "CVT Protection" torque limits, and the engine feels restricted because the ECU still expects communication from the TCM.
I have been working on defining the Driver Demand / Torque maps in EcuFlash to bypass these protections, but my current XML is very limited. I've managed to locate the 3D map at
Code:
5d01e
with RPM axes at
Code:
5cfee
and Accelerator Pedal at
Code:
5cfe8
, but the data alignment is still messy.
Current Setup:
  • ROM ID: 53230006
  • Inherits from: 52700006 (and 53230004 / Lancer10baseMIVEC)
  • Hardware: 2009 Lancer 2.0 NA
What I need: Does anyone have a more complete XML definition for this ROM? Specifically, I am looking for:
  1. Properly aligned Driver Demand / Torque maps.
  2. CVT-related limiters or "Safety Mode" maps that can be disabled.
  3. Target Idle tables for neutral (manual swap).
Any help or guidance on the correct addresses would be greatly appreciated. I am happy to share my current findings if it helps the community.
Thanks in advance!
File Type: bin
Old Feb 26, 2026 | 10:15 AM
Ali1983's Avatar
Ecu
Originally Posted by Coqueto
Hi everyone,
Code:
5d01e
with RPM axes at
Code:
5cfee
Code:
5cfe8
Current Setup:
  • ROM ID: 53230006
Thanks in advance!
replace ecu to manual
Old Feb 26, 2026 | 10:36 AM
RobbieOh's Avatar
5 Year Member
They could just bench flash the ecu to a manual rom of the same year.
Old Feb 28, 2026 | 12:10 PM
Ali1983's Avatar
Hi everyone,
Code:
5d01e
with RPM axes at
Code:
5cfee
Code:
5cfe8
Current Setup:
  • ROM ID: 53230006
Thanks in advance!
Is there any code you see , if there is code what is it
Old Mar 1, 2026 | 02:33 PM
jmcbrown's Avatar
Hi everyone,
Code:
5d01e
with RPM axes at
Code:
5cfee
Code:
5cfe8
Current Setup:
  • ROM ID: 53230006
Thanks in advance!
you need to flash manual rom , so if intrest cntact with me
jmcbrown146@gmail.com
Old Mar 2, 2026 | 01:16 PM
Coqueto's Avatar
[SOLVED] CVT to 5MT Swap - 2009 Lancer GTS - Torque Limiters Removed
"Hola a todos,
Escribo esta publicación para agradecer enormemente a la comunidad por toda la ayuda. Finalmente completé con éxito el cambio de CVT a manual (5MT) en mi Lancer 2009, y quiero confirmar que la solución definitiva para los problemas de modo de emergencia y limitador de par fue exactamente lo que muchos sugirieron: instalar una ROM 5MT nativa del mismo año y modelo.
Mi experiencia previa: inicialmente intenté modificar mi ROM CVT original (ID 52700006) manipulando la ECU, ajustando las tablas de limitador de par y control de flujo de aire . Si bien hubo algunos avances, el sistema seguía buscando la comunicación con la TCU y extraía la sincronización o limitaba el par en ciertos rangos. También intenté cambiar la ECU física por una manual, pero eso causó conflictos de comunicación del bus CAN con el módulo ABS, y el velocímetro dejó de funcionar.
La solución: Instalaba la ROM manual nativa usando EcuFlash. De esta manera:
  1. Limitadores eliminados: el motor ahora gira libremente sin las protecciones de torque específicas de CVT.
  2. ABS y velocímetro 100% funcionales: Como utilicé una ROM del mismo año del modelo, los protocolos CAN-bus coincidieron perfectamente y no hubo errores de comunicación con el módulo ABS.
  3. Comportamiento OEM: El coche se conduce exactamente como si hubiera salido de fábrica con una transmisión manual.
Para cualquiera que esté realizando este cambio: no pierdan mucho tiempo intentando parchear la ROM de la CVT; lo mejor es actualizar completamente a la versión manual. ¡
Gracias de nuevo por el soporte técnico!
Old Mar 2, 2026 | 01:47 PM
jmcbrown's Avatar
"Hola a todos,
You flash manual transmission rom with same four digit from the beginning
Jamspack
Feb 18, 2022 08:29 PM
EvoXEmma
Dec 27, 2020 01:18 PM
mady4g63
Nov 27, 2014 12:38 AM
c0ke
Jan 14, 2013 04:30 AM
I Kill Suckers
Jun 6, 2007 05:30 AM
