compression
Old Nov 5, 2004 | 08:42 AM
noriceoz's Avatar
compression
what compression do we run
Old Nov 5, 2004 | 08:58 AM
HobieKopek's Avatar
9.0:1. Next time please search.
EDIT: Moving btw since this has nothing to do with forced induction.
Old Nov 7, 2004 | 12:16 AM
TypeIII's Avatar
Well it kinda does... High compression + Forced induction = Boom
Old Nov 7, 2004 | 12:21 AM
Boeturbolancer's Avatar
9.5:1 would be the stock lancer and ralliart compression
Hobie... where did you get 9.0:1?
Old Nov 7, 2004 | 09:03 AM
Spiderman's Avatar
Hey boeturbolancer I was wondering if you got the thicker headgasket yet? I remember you saying you were going to do it but I wasnt sure if you went ahead and did it. If so, how much did it lower compression and how much did you raise boost?
Old Nov 7, 2004 | 03:34 PM
I never did it... decided to start playing with my mustang instead. The gasket i had planned was the 1.10mm which should have dropped me to about 9.1-9.2:1 and i was going to run 12-13psi on pump gas... 15 on race gas.
Old Nov 7, 2004 | 04:02 PM
rhyzin's Avatar
does dropping compression mean you can run more boost on stock rods?
Old Nov 7, 2004 | 04:14 PM
not exactly... the rods are still a factor as to strength. (if they can't take the power then lowering compression won't help since you are actually adding power that way)Lowering the compression ratio in the cylinder drops the temps down at max compression. Thus you are able to add some boost and in some cases add some timing back in. This gives you more power and tends to be safer. Remember for every 2 psi of boost you go up one point of compression. When your compression ratio gets up to around 15:1 you start getting preignition and detonation. This can be detered by higher octane fuels but running race gas for daily drivers isn't feasible for most. By dropping the compression down you can boost more before acheiving this volitile point in the combustion cycle.
Old Nov 7, 2004 | 04:18 PM
lookslikeanevo's Avatar
is there a gain to higher a compresion(if possible) in an n/s app?
Old Nov 7, 2004 | 04:26 PM
do you mean in NA applications? If so then yes there are great advantages in higher compression ratios for NA cars. A lot of higher hp/tq NA cars get there by running 11:1 or even 12:1 compression ratios. In the 2.0L setup we have, a jump to 11:1 could net you 30hp. However you'll need to have this setup tuned as the stock ecu will not adjust the fuel/timing properly for that high of compression.
Some drag applications run 13:1 compression ratios or higher. There is a limit though as the heat generated at those ratios is just as intense as in a boosted application. It is more controllable though since there is less to it but it still requires professional tuning.
Old Nov 7, 2004 | 04:30 PM
ya i meant n/a...what do you mean by having it tuned?...ems? ..and how do you actually raise the compresion?
Also keep in mind that lowering the compression ratios usually creates a drop in torque levels... raising them creates an increase. With proper tuning these drops/increases are negligeable due to the higher hp levels achieved but they are relevent.
Old Nov 7, 2004 | 04:31 PM
rhyzin's Avatar
hey boe, do you happen to know of any good books whether on NA or turbo?
Old Nov 7, 2004 | 04:32 PM
Spiderman's Avatar
Hey boe do you still have the gasket?
Old Nov 7, 2004 | 05:43 PM
No i don't... check with RRM. I left it there and i'm sure they still have it. Talk with Rob. If he still has it i'm sure he'll sell it to you.
As far as tuning for higher compression you could just use a piggyback like the emanage for it. You can raise compression by changing the piston top/height, decking the head down, increasing the bore size, etc. All these require motor work though.
As far as books go i don't know of any off hand. You can just go into any library though and research both Forced induction, Naturally asperated, and Nitrious applications.
Fhisre
Oct 25, 2014 01:03 PM
Enzo1089
56
May 19, 2010 06:25 PM
03RRVIII
Jan 16, 2009 08:03 PM
anyoneelse
Lancer Engine Tech
40
Sep 20, 2006 08:22 AM
Evo8urWRX
11
Jan 23, 2003 10:28 PM
