RPW Cam shaft and Cam Gear ARRIVED!!
Old Apr 30, 2003 | 10:14 PM
  #136
KMcW's Avatar
<--- Next mods = Header and cam from RPW!
Old Apr 30, 2003 | 10:55 PM
  #137
redbeard's Avatar
Originally posted by uranium9v
I got an SAFC II from Japan...cost $300, but I can't read japanese and need help with hooking it up to the ecu.
Ask the seller to email you text in English. It is the same as the first safc. Here is a link to one. http://apexi-usa.com/productdocument..._safc_wire.pdf
Also check out this thread: https://www.evolutionm.net/forums/sh...threadid=15891 great info. I wouldn't worry about hooking up the knock, unless you plan on doing turbo later. It would be too much trouble since there is so little documentation for version II. Hope this helps.
Oh yeah, glad you finally got it installed, but holy installation charge. Plan on any trips to the dyno/tuner soon?
Old Apr 30, 2003 | 11:14 PM
  #138
rhyzin's Avatar
can't wait to see what this car can do. cam stage 1 1/2 just might be my next mod! (rpw headers and fpr arriving friday, )
Old Apr 30, 2003 | 11:32 PM
  #139
redbeard's Avatar
Originally posted by Mitsiman
we will restate that camshaft as a stage 1 1/2 David Thomas
www.rpw.com.au
Will it be possible to buy a 1 1/2 stage cam that is fitted correctly, and would it need anything else besides afc?
Old Apr 30, 2003 | 11:34 PM
  #140
uranium9v's Avatar
the fitment issue thing was really no big deal...you could probably get a better deal on one!!!
Old May 4, 2003 | 05:24 PM
  #141
ghostrider's Avatar
This has since been fixed on all cams here and there were a total of two camshafts in the USA that had to be either
(A) Re tapped another 0.4mm (Total of around 3 threads)
(B) Fitted with a 1mm washer between the bolt and cam pulley
Anyway I hope this clears up everyones questions - to clarify there is no problems associated with the camshafts and we have since gone back to our manafacturer and we will also check all future camshafts ourselves before sending them out to ensure the tapped length is correct.
Feel free to ask any questions guy's I will try my best to answer them.
David Thomas
www.rpw.com.au
So if we order from Vision, will we be getting the new cams that don't need retapping? Or is there still a chance to get one that needs to be retapped?
Old May 6, 2003 | 08:32 PM
  #142
Mitsiman's Avatar
All future cams will have that problem rectified in the future and there are no other fitting problems.
Old May 6, 2003 | 08:56 PM
  #143
agsmooth84's Avatar
ill be ordering mine soon, how much of a horsepower difference will there be between the 1 and 1.5 cams
Old May 12, 2003 | 11:50 AM
  #144
Mitsiman's Avatar
I do not have a hp difference at this time between the 1 and 1.5 cam profiles and as always they will vary. If you are going to be fititng an aftermarket fuel piggy back system then go the 1.5 as it will work better on the car for larger gains. \
Think of it more this way - the more mods you are going to do to the car - the larger the cam you can go within reason.
David Thomas
www.rpw.com.au
Old May 12, 2003 | 11:58 AM
  #145
mark2002lancer's Avatar
how much for a turbo cam and what else do i need to run it
Old May 12, 2003 | 02:57 PM
  #146
HobieKopek's Avatar
If you want prices, talk to vision imports.
Old May 13, 2003 | 11:12 AM
  #147
Mitsiman's Avatar
All camshafts are the same price regardless of which grind you wish to run on the vehicle. But as they say - contact visions for pricing.
David Thomas
www.rpw.com.au
Old May 13, 2003 | 05:24 PM
  #148
redbeard's Avatar
Do your other US vendors carry these products?
Old May 15, 2003 | 11:23 AM
  #149
Mitsiman's Avatar
No one carries them as in stock. But all of our other vendors can order them and we do carry a large range in stock ourselves in perth all the time. They are only 7 days on average to ship out.
David Thomas
www.rpw.com.au
Old May 15, 2003 | 02:01 PM
  #150
redbeard's Avatar
Can you provide some prices, including shipping? You can pm them to me if you like. Thanks.
