RPW Cam shaft and Cam Gear ARRIVED!!
Did they ship the torqe specs with the cam and gear.
If any one does try to do the cam by them selfs make sure you unbolt the old cam as carfully as you put the new one in becouse damage can be done if taken out wrong as well.
Yes, you also need afc (300), valve springs (150), and fuel pressure regulator (?) BTW, there are good deals for the Apexi safcII on ebay. I just bought the safcII and the stage 2 is my next mod. I just can't wait to hear about this current install.
