RRM intake manifold and throttle body ?s
Also have to think about what you want out of the car, caming is great if you plan on staying NA but if you have any thoughts of going FI it could end up being a good 1000$ waste of money. Personally I've decided to just get my suspension done and then, if money is available, turbo the car. NA is fun and all, and I'm sad to say if I had a honda I'd stay NA, but I don't feel like spending 1000$ with install for a camshaft and deal with a lumpy idle and all that or 1200$ plus install for a ported head when I'll be lucky to get 15 hp out of the deal. For 4000$ I can be sitting at 200 hp easy. Which is the better option?
Good call ambystom
For cams - hit up vision imports.com. That's the only place i've seen so far... believe me, i've searched.
My exhaust set up was Kami header / RRM test pipe / Greddy cat back = hella LOUD.
I opted for a hi flow cat with my kami headers since i have the OEM exhaust on again ( hole in the resonator
I'm going to stay N/A for now so i'm looking into cams & pistons but like he said - it all depends what you're gonna do with the car.
) I'm going to stay N/A for now so i'm looking into cams & pistons but like he said - it all depends what you're gonna do with the car.
Originally Posted by Ozdriver
which is better as far as headers go RRM or RPW ? this question is obviously directed to non venders
Originally Posted by Offender
Also Kamikaze headers usually leak, just in case you were thinking about them as well.
Personally, i've had the kami headers for almost a year now and no leak problems. Just my .02 though - use lock nuts when bolting the downpipe to the header. They won't loosen like the regular nuts will. Easy peasy.
