RRM intake manifold and throttle body ?s
Old May 18, 2006 | 12:56 PM
  #106
Boeturbolancer's Avatar
I know this is knocking the product... but doesn't that phenolic one look like as@ on the inside bore? It looks like someone just took a reamer to the inside to open it up. Like it was done on a bench by hand. I'd have figured they'd be CNC'ing these.
Sorry it's not sealing for you... guess they didn't know that the Mirage TB is different than the Lancer TB. Kind of a big OOPS. Hit up RPW and they will hopefully get things corrected for you. May take some time since they are in Australia though.
Good luck. For now i'd just put the regular gasket back in and run without that spacer. Just disconnect the coolant lines to the TB and your temps on it will go down bigtime. Just loop one to the other and bam... you're done.
Old May 18, 2006 | 01:37 PM
  #107
Ozdriver's Avatar
I have spoke to someone at RPW but they want a pic of the throttle body now that I have sent them that pic of the spacer I had to buy a new stock gasket in order to get my car back togeather since its my daily driver
I don't want to or have the time to take my car back apart so if anyone has a good pic of the IM side of the throttle body could you please post it or send it to me one way or another I would greatly appreciate it ...
is that safe to do with the coolant lines?
Old May 18, 2006 | 04:03 PM
  #108
coolant lines looping is fine... it's a warm up feature used for cold climates. However it will not hurt the car in anyway. I have never seen any ill effects in cold weather either. I grew up in NY and did this to many cars. It's an old trick.
Old May 18, 2006 | 07:57 PM
  #109
ROCK's Avatar
IM looks the same as an IM they should have. Strange. Don't tell me they are going to blame the T.B.
ROAD/RACE
Old May 18, 2006 | 08:08 PM
  #110
Ozdriver's Avatar
huh..... you learn something new every day thanks for the info
I don't know what they are trying to get at...... it seemed kind of odd to me I mean you can obviously see by the pic of the gasket that there is something wrong... IMO but I don't know ......
thats it I'm only dealing with RRM from now on
Old May 19, 2006 | 10:06 AM
  #111
It's probably simple... RPW has had some issues before where they try to use Mirage parts on the Lancer. Some things are the same and some are not.
Their exhausts didn't work out right on the lancer as the midpipe was different. They've since corrected that. The cams in the mirage are different than the lancers... They've since made some changes to the cams for better application in the lancer. This looks like the same thing... they used the mirage spacers and the lancer is different.
Looks like your just one of the first guys so it wasn't caught yet. I've seen a couple others so you're not alone.
Sorry this had to happen to you...
Old May 19, 2006 | 01:13 PM
  #112
Ozdriver's Avatar
its not a big deal really..... I just want it to get straightened out since the spacer was around $50.00 the other spacer I got fit great don't get the wrong idea I'm not bashing RPW in any way this is my first expeirence dealing with them..... I just need a pic of the throttle body and I think everything will be straightened out
Old May 19, 2006 | 01:19 PM
  #113
MIA2FASLANCER's Avatar
So any difference? what are ure gains can u feel it? how does it drive?is it worth it? hows the powerband? we all want to know!
Old May 19, 2006 | 01:24 PM
  #114
Ozdriver's Avatar
Originally Posted by Ozdriver
just figured I would let any one that may be wondering know what I have noticed .... there is no difference in the sound of the engine after I installed that I can tell (for me that was a plus) noticable gains on the highway at high rpms... it was kind of an expensive mod for what you get IMO but I think it will be worth it in the long run..
Old May 19, 2006 | 06:53 PM
  #115
Ozdriver's Avatar
noone has a pic of the manifold side of the throttle body?...... ROCK do you think you could take a pic of my core when you get it and post it on here for me? (you should get it mon or tues I sent it out this past monday) if not its no big deal but if you could I would really appreciate it
Old May 20, 2006 | 07:47 AM
  #116
Ozdriver's Avatar
ok I found the pic I need..... hopefully everything works out from here
Old May 22, 2006 | 11:50 AM
  #117
Ozdriver's Avatar
still waiting for a response from RPW
Old May 22, 2006 | 11:00 PM
  #118
ROCK's Avatar
Yea. It looks like a Lancer T.B.
ROAD/RACE
Old May 23, 2006 | 07:15 AM
  #119
I still gotta wonder... Why did they need to see a picture of the TB? Don't they have one? Didn't they base the design off of it or did they just figure a mirage Spacer would work? It just makes no sense that a picture will show them anything more than the stock gasket would.
Do you understand where i'm coming from? It just doesn't make any sense what they are having you do. It seems like a stall or something.
Old May 23, 2006 | 10:39 AM
  #120
Ozdriver's Avatar
yea it doesn't make sense to me.... I still havent heard back from them since I last emailed them I don't know what is going on......
on another note have you guys at RRM recieved my cores yet? they chould be there any day now hopefully the flooding we had last week didn't slow things up
