Need Help
Old May 2, 2006 | 01:59 PM
Stumpy221's Avatar
Need Help
I just installed a ported Intake manifold and Fuel rail.
However im having a problem
Upon startup, im hearing a loud hissing noise.
And i am running Lean
What coul this be?
Current mods excluding what is mentioned: Exhaust, Headers, Piggy back, intake, and TB
thanks
Old May 3, 2006 | 12:13 PM
SLVROZ_03's Avatar
vacuum line???
Old May 4, 2006 | 08:24 AM
Blacksheepdj's Avatar
+1
Check to see what you missed.
Old May 4, 2006 | 10:43 AM
Stumpy221's Avatar
nah, all lines are connected, i double checked everything.
when i did get a chance to drive, the hissing seemed to stop for a little. car idles like crap too.
could it be the gasket? not creating a seal?
Old May 4, 2006 | 10:53 AM
twisty1251's Avatar
Sounds like you have a leak between your intake manifold and head, or maybe your injectors aren't sitting in the fuel rail correctly.
grab a can of Brakeleen and spray it generously where the IM connects to the engine. if your car revs up a bit when you do this, you have a leak. make sure your torqued all the bolts down, and the gasket is sitting in there correctly.
Old May 4, 2006 | 11:18 AM
civilrage's Avatar
yes make sure u check that fuel rail for sure.. i had a similar problem with one of my injectors... in anycase, reset your piggyback and relearn.. take it easy for a hundred miles and idle should be fine.
Old May 4, 2006 | 11:26 AM
rhyzin's Avatar
did you tighten the intake manifold bolts starting from the middle and alternating out?
Old May 4, 2006 | 12:22 PM
Stumpy221's Avatar
ok thanks to everyone for the advice
just bought some sealant, i just need to wait till fri to get the missing bolt from the TB
Old May 4, 2006 | 12:24 PM
SLVROZ_03's Avatar
^^^ "missing bolt"??? problem solved???
Old May 4, 2006 | 12:26 PM
Stumpy221's Avatar
lol, nah that happened from when i put the stock manifold back in
i had two, one i ported myself and the stock one
Wait fuel injectors? How can they sit wrong in the fuel rail?
Old May 4, 2006 | 01:51 PM
twisty1251's Avatar
if you did a bad port job that could also cause it to idle bad.
alexc
Jun 29, 2015 03:15 PM
FL4TLINE
23
Jul 5, 2012 06:45 PM
jaredh
11
Sep 21, 2009 06:17 AM
cecilia
May 19, 2003 05:12 PM
topsnwbrdr
Lancer Engine Tech
106
Jun 21, 2002 11:38 PM
