JET v-force
Old Apr 22, 2003 | 03:49 PM
uranium9v's Avatar
JET v-force
Any idea if this will work??? Looks like a SAFC but with a bit more to it.
From the JET site
" The JET V-Force Power Control Modules (PCM) uses the same computer tuning technology found in JET's popular domestic tuning products. A 20Mhz RISC microprocessor optimizes the ignition spark advance and recalibrates the fuel map for optimum horsepower and acceleration.
Modified Ignition Curve
Recalibrated Air/Fuel Ratio for Maximum Performance
Improved 1/4 Mile E.T's
LED Read Out
On/Off Override Switch"
Old Apr 22, 2003 | 05:00 PM
defeated26's Avatar
i have some n00b questions:
does it modify your ignition curve and air/fuel ratio automatically or do you have to tweak it yourself?
how does it actually connect to your existing ecu (is it just like 3 wires you solder or what...)?
does anyone already have one?
how much do they cost?
Old Apr 22, 2003 | 05:38 PM
Smoktout's Avatar
OZBOTS had one and when he put his turbo on it got all ****ed up....jetforce gets a big in my book, although i've never actually known anyone personally who had one.
Old Apr 22, 2003 | 06:21 PM
DRC Imports's Avatar
i sent jet my ucu and they upgraded it. only downfall is when i get an intercooled turbo, the ecu will only allow up to 6 psi. anything more and i have to retard the timing. it gave me alot of power with the few mods i have (19-22 whp)!!!!
Old Apr 22, 2003 | 10:01 PM
uranium9v's Avatar
what did they do to your ecu??
Old Apr 22, 2003 | 10:18 PM
change the fuel/air ratio and advanced the timing quite a bit. they have some kinda smart chip that gives you same % of hp from a tap of the gas to wide open throttle. I LOVE IT!! best $300 ive ever spent...
Old Apr 29, 2003 | 10:40 PM
lanceroz84's Avatar
do they custom program according to specs you provide ie bigger tb higher compression ect. or is it a default tune please feed back
Old Apr 29, 2003 | 11:01 PM
yeah you fill out form they provide with you r mods and they adjust accordingly
Old Apr 30, 2003 | 03:26 AM
evo_dan's Avatar
Who are these people and how do I get a hold of them? PM me please.
