Thermostat
Old May 5, 2003 | 02:31 PM
ROB281's Avatar
Thermostat
Has anyone here changed their thermostat, I heard that if you change it to cooler temp thermo that you will actually improve your performance. Ex. you might be runnin a 190 thermo, what this means is that until your engine hits 190 you will retain all heat in the block therefore keeping the block at a constant 190 degrees or hotter. If you change to a 185 thermo you've just cut your engine temps down by 15 deg. and thermo's are dirt cheap too. But this is just a suggestion
Old May 5, 2003 | 05:21 PM
bahamut's Avatar
You shouldn't worry about it until you flush your radiator. Then again, it might affect your emissions. Every car needs a certain temp to run properly.
Old May 5, 2003 | 05:32 PM
Tristar's Avatar
Urban Legend man, the only thing a cooler thermostat will do is cause your engine to run cooler than its proper operating temp. It might effect performance a little, but get ready for a car thats really cold to drive during winter.
Old May 5, 2003 | 05:44 PM
ROB281's Avatar
well in that case I'll just leave mine be, thanks for the info
Old May 5, 2003 | 06:41 PM
RollerPyro's Avatar
Just as a side note, it doesn't sound good for your engine either. The thermostat in there is set for the optimal operating temp., any colder and you're probably putting more wear on your engine.
Raceghost
Aug 10, 2018 10:39 PM
m34g63
AWD Motorsports - Florida
Jul 15, 2010 05:38 PM
expl0d
10
Mar 13, 2007 04:21 PM
yesevo
28
Sep 8, 2005 01:20 PM
Evo_doer
May 12, 2004 08:14 PM
