Blown motor - Engine Swap?
Old Oct 4, 2006 | 01:50 PM
  #46
Blacksheepdj's Avatar
Originally Posted by Foxphyre
the thread continues and a solution is found through collaboration.
I'm as amazed as you. And I haven't deleted a single post.
Old Oct 11, 2006 | 09:24 PM
  #47
r3z0nate's Avatar
I think I've seen you driving around, you should come to some local events when you get everything fixed.
Old Oct 12, 2006 | 07:10 PM
  #48
Elvis's Avatar
5) if using an ES paltform, you'll a leg up on weight comparing to OZ and stock RA.
is and ES really lighter in weight than an RA or OZ. couldnt be much youd think?
Old Oct 12, 2006 | 07:23 PM
  #49
ambystom01's Avatar
Depends on whether you have air conditioning.
Old Oct 13, 2006 | 08:15 AM
  #50
I don't know how meaningful this is, but the curb weight on the OZ is listed as being 25 kg heavier than the ES. But nothing on the Internet is 100%...
Old Oct 13, 2006 | 08:53 AM
  #51
drucea's Avatar
I thought the only weight differences would be in the better suspension for the OZ, that is, if both cars have A/C, both are the same tranny, etc....I could be wrong.
Old Oct 13, 2006 | 08:59 AM
  #52
Body kit weighs a bit more, sway bar weighs a bit more, etc. All the little trinkets that the OZ/RA got add up, you know?
Old Oct 13, 2006 | 11:43 AM
  #53
rhyzin's Avatar
mitsu manual says the OZ is 31 lbs heavier ES 5-speed to OZ 5-speed. if we're talking the bare bones ES that's sold in Canada, the OZ is 97 lbs heavier.
Old Oct 13, 2006 | 08:39 PM
  #54
LancerOZ Boy's Avatar
When you have a lttle 120 pound guy driving like me..it helps
Old Nov 1, 2006 | 05:22 PM
  #55
iyi0521's Avatar
Question. I had heard about a JDM V-6 that fit in the Lancer. Something from the FTO? Has anyone pulled that off successfully? That someone verfied?
Old Nov 1, 2006 | 05:36 PM
  #56
mitsuozboi's Avatar
ive never heard about anything v6 going in a lancer. Im sure its possible.
cool... so at least I know. With the weight I saved on my carbon fiber I weigh as much as an ES. WOOT!
Old Nov 1, 2006 | 07:06 PM
  #57
drucea's Avatar
rpw had a list of engines that fit good into the lancer and i think one was the v6 from the fto. not positive though.
Old Nov 1, 2006 | 07:22 PM
  #58
atilla's Avatar
lanceradam and i were talking about a V6 swap, i forget the model designation but it would definitely be sweet to do. AFAIK it's not an engine that can be found stateside.
Old Nov 3, 2006 | 07:26 PM
  #59
LancerNOS's Avatar
Hey guys, i have been doing the dissasembly on the motor and i have a question for those who have done this. I tried to pull out the motor w/o removing the trans off the mounts (manuall tranny) but the input shaft is too long..... A) should I pull the trans out with it (either from the bottem or from the top......hopefully top cause im doing it in a garage.) B)loosen the trans mounts and angle it, or C) SOMEHOW someone has pullled it out without dealing with the trans. Hopefully someone has dealt with this before.
Old Nov 4, 2006 | 08:09 AM
  #60
PM HotShot940 - he's pulled his motor recently.
