Electronics Question
Old Dec 21, 2006 | 12:30 PM
Racer24x's Avatar
Could I use the Apex'i SAFC2 Fuel Controller on a stock setup for now and still use it in the future on turbo?
What exactly does it do, or is it basically self-explanatory(ie: fuel-controller)?
What are the benefits?
What are all the electronics one would need for a turbo setup?
Old Dec 21, 2006 | 12:36 PM
Wallesasuaz's Avatar
I would suggest you run a search on : SAFC2
You'll get tons of info!
Old Dec 21, 2006 | 12:41 PM
blaze_125's Avatar
https://www.evolutionm.net/forums/fo...play.php?f=175
Hopefuly this link will work too(obviously some thread will be useless, but plenty of good info if you dig through some):
https://www.evolutionm.net/forums/se...archid=3715866
https://www.evolutionm.net/forums/sh...highlight=safc
been a while since the last time I got to use this
Old Dec 21, 2006 | 12:45 PM
Blacksheepdj's Avatar
Yeah, the SAFC will be fine before/after turbo.
All it does is let you add or remove fuel from the Air/Fuel mixture.
Benefits are increased power and increased MPG.
It would suffice for a turbo setup. An RRM piggy tuned for turbo would be another great choice. Mostly, you just use mechanical parts to tune for the turbo (injectors, FMU, etc).
Old Dec 21, 2006 | 01:31 PM
Mirage2.0's Avatar
I gained 7whp on dyno from S-AFCII.
Angeloj-Miranda
Jun 5, 2015 08:38 AM
mscorei
10
Sep 9, 2007 05:44 PM
amstel78
17
Apr 5, 2007 08:56 AM
ninjadoc
AEM EMS
56
Jan 30, 2006 07:38 AM
BenM
Feb 5, 2004 09:35 PM
