fuel rail question
Old Jan 18, 2007 | 09:49 AM
Swift Drift 14's Avatar
fuel rail question
Is the Mitsubishi Lancer ES fuel rail the same as the EVO? I have an 05 Lancer ES and I've noticed alot of things are the same between the ES and the EVO. Please help me out because I need an upgraded fuel rail for my ES and haven't found one yet.
Old Jan 18, 2007 | 10:07 AM
senate6268's Avatar
Road /// Race has an upgraded fuel rail for the 4G94. It is bored out to allow for better fuel flow. A while back there was also a billet fuel rail capable of supporting 1600+HP but was discontinued.
As for the EVO fuel rail fitting, it is to my knowledge that it either doesn't fit or no one has attempted to fit it to a 4G94 engine.
Old Jan 18, 2007 | 10:32 AM
ROCK's Avatar
Thanks for the plug but the rail we currently have is for 02-03 Lancers not the 05. The rail alone will not do much for you unless you have mods. The 05 rail is actually larger than the 02-03 rail so there is no benefit for swapping it to a larger rail, plus the EVO rail does not fit the ES. It looks close but it is different enough to cause you nightmares.
ROAD/RACE
Old Jan 19, 2007 | 06:27 AM
Blacksheepdj's Avatar
To reiterate what's already been said,
NO, the Evo rail won't fit.
NO, the bored fuel rail won't fit either.
Thread cleaned. For sale posts go in the Classifieds...
Old Jan 20, 2007 | 02:17 PM
CityKnight's Avatar
ROAD/RACE
Do you mean bigger overall, or a bigger Bore?
If just the bore, then how much bigger is the '05 Rail in comparisson to the '03 Rails?
Old Jan 20, 2007 | 02:51 PM
lancerman360's Avatar
The RRM 02-03 is just bored out. From what I remember
Old Jan 20, 2007 | 09:56 PM
Elvis's Avatar
doesnt it just provide more fuel behind the fuel injectors. if so other mods would be the only thing making it beneficial. lots of bolt ons or turbo.
Old Jan 21, 2007 | 12:21 AM
ambystom01's Avatar
It helps to get rid of some of the hesitation inherent to a stock motor.
Old Jan 21, 2007 | 06:31 PM
DickMorgan's Avatar
ROAD/RACE
looks like u know from experience lol
Old Jan 24, 2007 | 04:55 PM
ROCK's Avatar
I ahave a little experience, yea.
ROAD/RACE
Old Jan 26, 2007 | 03:53 AM
CityKnight's Avatar
...but how different are the 03 rails from the 05s?
Can we swap 'em?
Old Jan 26, 2007 | 08:49 AM
ROCK's Avatar
They are different with regards to return/returnless but the injectors are also in different spot. If you put the wrong IM with the wrong rail, you will have fuel leaks and in one case I heard of a dude who burned his car to the ground!
ROAD/RACE
Old Jan 26, 2007 | 11:05 AM
ambystom01's Avatar
Can we swap 'em?
No and why would you want to? You can get a bored 03 fuel rail for cheap.
bigginth
Lancer Engine Tech
Oct 29, 2014 05:41 AM
GTS08
Lancer Aftermarket Forced Induction Tech
13
Mar 12, 2011 01:26 PM
lancer2008
Lancer Engine Tech
Jul 24, 2010 01:59 AM
donvito1
May 2, 2004 07:45 AM
