RRM axleback exhaust discussion thread
Old Jul 21, 2007 | 12:00 PM
  #286
Jake26's Avatar
Originally Posted by 08Lancer89
Lol okay Jake looking forward to pics! That idea may works
hahah well i just stood in the back of my car and the exhaust is NOT in the middle i might have looked at it wrong.
Old Jul 21, 2007 | 02:35 PM
  #287
the_cosworth's Avatar
Here is a photo of the car with the exhaust straight
and here are some of the videos of it going, sorry about the quality of sound on the driving one, i used a canon powershot sd400 for it. It is a deeper rumble inside the car than you can hear on the video.
Old Jul 21, 2007 | 06:01 PM
  #288
08Lancer89's Avatar
How did you get yours perfectly centered??
Old Jul 21, 2007 | 10:33 PM
  #289
Jake26's Avatar
yeah thats what i wanna know, did u use the stock bushings or did you gets yours replaced and welded on!? BTW nice t-shirt
Old Jul 21, 2007 | 11:02 PM
  #290
ha thanks, i didnt know you could see it, i think it is oneil or something
I just unbolted the left bolt letting some of the tension off so that the right bolt pulled it right (seeing as my exhaust was sitting left) I dont think the bushings are meant to be there to hold it straight or not I think they are just there to keep it from hitting the road. wow hope that made sense had a few tonight
I am thinking of going to get a washer for the m14 bolt and putting it in between the left spacers of the exhaust so I can tighten them down properly but still have them offset
Old Jul 21, 2007 | 11:17 PM
  #291
chetman7's Avatar
^^ lol that movie gave me a headache...so much movement
Old Jul 21, 2007 | 11:25 PM
  #292
sorry I hung the camera from my rear view mirror, I didnt want to try to shift at the same time
Old Jul 22, 2007 | 05:48 AM
  #293
08Lancer89's Avatar
can you post pics of the offset bolt for us please, after you recover lol
Old Jul 22, 2007 | 10:23 AM
  #294
haha all is well, just had family in town.
It is harder to explain than I though, i guess I cant communicate very well, that must be why I sit and do math all day. Ok so having both bolts tight as hell pulls my exhaust toward the drivers side, if you loosen the bolt on the drivers side it will relieve tension on the mounting plates and let the passenger side bolt pull the exhaust back straight. I just kept loosening it off (the bolt) until the exhaust tip was straight. Like I said I dont think this will be a permanent fix but it works for now until I hear or think of something better.
maybe someone from RRM could answer this question for us?
Old Jul 22, 2007 | 10:32 AM
  #295
08Lancer89's Avatar
Rob you have a Fix for this???
Old Jul 22, 2007 | 10:54 AM
  #296
graypearlgts's Avatar
i havent messed with the exhaust on my car at all yet so it is just a thought i had looking at the picture above, but what if you bend the metal arm that holds the rubber bushing to the body slightly towards the passenger side... this would eliminate having to loosen the bolts at all and prevent exhaust leaks by eliminating the need for spacers... again i havent so much as messed with it so i dont know... just a thought
Old Jul 25, 2007 | 10:06 PM
  #297
ok so it was only a temporary fix, I started to loose back pressure a bit under heavy load so I bolted it back up tight
anyone else have any luck fixing there exhaust?
Old Jul 26, 2007 | 12:10 AM
  #298
Brian@RRM's Avatar
the way the new style flanges are designed u have to get the exhaust exactly in the center and then u tighten one bolt and then the other. it is alittle more involved than just bolting on, but they do fit great after they are fitted the first time.
Old Jul 26, 2007 | 06:30 AM
  #299
08Lancer89's Avatar
so hang it first then bolt it up??
Old Jul 26, 2007 | 06:51 AM
  #300
Does that mean if we have already hung it then that we have screwed it up? or can we unbolt it and try it again?
Just curious because of the way you said fitted the first time.
