Cleaning TB + IM, HELP!
Old Jun 1, 2007 | 10:20 AM
Boni's Avatar
My throttle body has become rusted on the inside after sitting for about 2 years. it opens up fine, but there is rust all around it. What do you guys suggest to clean it? A buddy of mine told me WD40 but I wanted to ask here before I go crazy with that stuff on it. Also I have a 4G93 mirage intake manifold and it is pretty dirty with some white crap and a little rust, what can i use to clean this? oh and there is pieces of the old throttle bodies gasket stuck on it that I cant get out, I used a razor blade on some of it but it looked like I was scratching the metal and im sure that isnt good to do... any ideas/suggestions would be awesome, thanks.
Old Jun 1, 2007 | 10:24 AM
blaze_125's Avatar
First, I'd take the IM and TB off the engine
Then I'd clean the whole thing with brake cleaner
And finish it with a good rinse.
Old Jun 1, 2007 | 10:25 AM
ambystom01's Avatar
I used Seafoam spray to clean mine and it worked pretty good but I only had carbon buildup not rust.
Old Jun 1, 2007 | 10:27 AM
Boni's Avatar
Both of these items are off of the car, in my garage. Now if I use brake cleaner, what do I have to remove from them? everything? I don't wanna mess up the parts attached to them like the fuel rail, lines, etc..
Old Jun 1, 2007 | 10:29 AM
ambystom01's Avatar
If you're gonna use brake cleaner, remove everything from the TB and IM. I've heard that brake cleaner eats through rubber eventually so it's better to be safe than sorry.
Old Jun 1, 2007 | 10:47 AM
Lazeum's Avatar
You can buy as well some Throttle body cleaner at auto shops.
Works as good as brake cleaner.
For the rust, I'm not sure it will work. You'll need something else + you need to neutralize it. WD40 can be helpful, then.
Old Jun 1, 2007 | 10:53 AM
Walkingchaos's Avatar
I cleaned the hell out of the TB and IM before I put them on my car with guess what . . . IM and TB cleaner You can pick the stuff up at major auto stores. It stinks something fierce but its made to remove the types of deposits you find on them. As for the gasket, get all the old stuff off, not a big deal if you scartch it, the new gasket will seal it, just dont scratch anything too deeply.
Old Jun 1, 2007 | 11:13 AM
SLVROZ_03's Avatar
Try the cleaners, then if they don't get the rust off...maybe try a Dremel flap wheel?
Old Jun 1, 2007 | 12:34 PM
Boni's Avatar
cool, ill check out auto zone and get some IM and TB cleaner, if they dont have it ill just use brake cleaner, thanks for the advice fellas, ill post up and let you guys know how it goes, and what I used.
Old Jun 4, 2007 | 08:17 AM
btw if anyone needs a solid low mileage IM for either a portjob or a replacement drop me a line. Ive got one Ill give up for 85$ shipped anywhere in the continental US. I ported mine in a few days, its SOO easy.
Old Jun 4, 2007 | 10:06 AM
kungfugirl's Avatar
sand paper and time?
Old Jun 4, 2007 | 10:57 AM
Evo666's Avatar
I took off my intake mani, bought 3 cans of intake cleaner(yes it requires a lot) and found a suitable place to kill grass/bugs/life
Old Jun 4, 2007 | 11:05 AM
drewbad's Avatar
Steel wool should help.
