ROAD/RACE- Pulley 2008 Lancer
Old Jul 21, 2007 | 01:23 PM
  #136
MaRcO_GTS86's Avatar
I just installed my pulley today, and I do have to say, anyone who has the money, and the time to install it (15-20 minutes lol) should definitely buy the RRM Pulley. You can really tell the difference in 1st gear, and 3rd gear really picks up some speed. It's a notable difference, so GOOD JOB RRM .
I also installed my RRM Rear Strut Bar, and I must say, my trunk looks really sexy with that add on. I'll post pics either later today or tomorrow. It's to hot right now to be stand outside lol.
Old Jul 21, 2007 | 08:17 PM
  #137
ROCK's Avatar
NICE. Glad you like them.
ROAD/RACE
Old Jul 22, 2007 | 06:06 AM
  #138
08Lancer89's Avatar
looking forward to pics!
Old Jul 22, 2007 | 11:01 PM
  #139
Sithlord9849's Avatar
Question
Question: In one of the instructions that someone posted it said to dab the screw with oil before you bolt on the new pulley... I didnt do this when I installed mine. Is this bad???
Old Jul 22, 2007 | 11:34 PM
  #140
08Icelancer's Avatar
Originally Posted by WhiteGTS18
I was also wondering if the bolt needs to be torqued or just put on as hard as you can go. and also do you need to re-turn the tensioner bolt counter clockwise, and does it matter how tight or loose the bolt is? is the tension automatically set correct once the bolt is turned back counter clockwise?
there probably is a specific tourge that should be but if you just impact the **** out of it im sure it will be fine... i havent actually looked but i am geussin the tensioner is an automatic tensoin so when you put your wrench on the nut you are not actually loosing the nut just moving the tensioner to release the tensioner of the belt and one the belt is off you can let go of the bolt and it will spring back to where it was...you will see what i am talkin about once you get under the car look at it...i woudnt recommend putting the crank pully on by hand with out a tourque wrench
Old Jul 23, 2007 | 07:11 AM
  #141
WhiteGTS18's Avatar
thanks 08icelancer!
I figured it was like that but I didn't think u had to hold the bolt. I thought you would turn it clockwise to get rid of tension then turn it back counter clockwise to put tension back on.
also ROCK I think you have probably answered this before but is there a reason you only did the crank pully and not a P/S and ALT one?
Old Jul 23, 2007 | 02:39 PM
  #142
Blacksheepdj's Avatar
Nope, you'll be fine. It's just something extra you can do.
Old Jul 24, 2007 | 06:56 AM
  #143
specialk8519's Avatar
Those of you who have the pulley or RRM. What kinda of hp gains are you getting? Unorthodox Racing says they get 8hp-16hp gains with theirs. Thats a pretyy big gain. Is this what I can expect when I get mine? Once i pay off my tickets of course
Old Jul 24, 2007 | 08:36 AM
  #144
ROCK's Avatar
The other guys are lying, BIG. Sorry but they have to be.
ROAD/RACE
Old Jul 24, 2007 | 08:38 AM
  #145
SeRious08's Avatar
The largest gains I have ever seen to the wheels with a pulley (undrive) was 5 whp. Most average about 3.
Old Jul 24, 2007 | 08:54 AM
  #146
Rabidhamster's Avatar
you MIGHT MIGHT see those gains in the lower rpms, but peak .. I would be suprised to see more then 5hp on an N/A engine.. some s/c cars you will see way more.. but.. in that case your not only doing a light weight pulley .. if it's an underdrive too you you also are doing the same as changing the s/c pulley = more boost
just a lightweight pulley (remeber RRM's isn't an underdrive) 5hp peak is great. you'll as said already see more in the lower rpms and your throttle response .. speed your engine climbs in revs .. then peak hp gains.
Old Jul 24, 2007 | 11:10 AM
  #147
Yeah, I figured 8-16 was very high for a pulley. Just thought I would ask the pros.
Old Jul 24, 2007 | 12:36 PM
  #148
Eagles GTS's Avatar
How difficult was the install. Do I need an impact wrench to install it CORRECTLY.
Old Jul 24, 2007 | 01:56 PM
  #149
Install was fairly easy actually. And yeah, I would recommend an Impact gun, or you will be there for a while trying to pry it off. Didn't take more then 15 minutes to install.
Old Jul 24, 2007 | 04:47 PM
  #150
jRox's Avatar
^^i'll be stopping by your place in about a month to use your impact gun.
