ROAD/RACE- Pulley 2008 Lancer
Old Aug 7, 2007 | 09:19 AM
  #226
SeRious08's Avatar
Rob, just make a stronger crank and end this silly argument.
Old Aug 7, 2007 | 10:15 AM
  #227
polar1120's Avatar
Know what Rob for the few geniuses in here that think they know everything and want to keep their car stock you have plenty more willing and waiting to buy your stuff. Pay them no mind. Every product I have bought from you guys works amazingly and worth every penny I spent. So don't worry you'll still have one customer here.
Old Aug 7, 2007 | 06:35 PM
  #228
ROCK's Avatar
It is all good.
ROAD/RACE
Old Aug 8, 2007 | 03:00 PM
  #229
jRox's Avatar
guuuys. im having trouble installing the pulley . i cant seem to loosen the belt by the tension pulley. i cant figure out what im doing wrong, IF im doing anything wrong. i'm 100% sure its the right pulley, trust me, i checked a thousand times.
how come it was so easy for you guys? took you guys like 15m.. could it be that my engine is still TOO new? i have about 2800miles.. idk, just guessing. HELP
Old Aug 8, 2007 | 03:03 PM
  #230
stEVOx's Avatar
well assuming its similar to the RA install, yes it is a PITA to move the tentioner, i had to use these vice grip things to move it, also alot easier if u have some1 to help u
Old Aug 8, 2007 | 04:36 PM
  #231
Eagles GTS's Avatar
I just got my pulley today but its raining and dont have a garage so ill have to wait till the morning. I cant wait.
Old Aug 8, 2007 | 04:41 PM
  #232
SeRious08's Avatar
Hmmm, I thought you had sold this to Mark......
Anyways, you have to loosen it from the top. Raise the hood and use a long (12 inches or longer) 5/8 wrench. Place it on the tensioner bolt and turn counter-clock wise (towards the fire wall). While its pushed all the way back, have a friend slide the belt off.
At least thats how mine came off. Mark help me.
Old Aug 8, 2007 | 04:53 PM
  #233
polar1120's Avatar
you can also do it from the bottom the the same wrench. It's the tensioner right above the pulley. It feels spring loaded but comes off in a snap. After that it's a breeze.
Old Aug 8, 2007 | 05:17 PM
  #234
jRox's Avatar
you sure its counter-clockwise? RRM directions say clockwise.
anyway, so if you loosen the bolt a bit on the tensioner, it should be easy for the belt to come off? cause i did loosen the tensioner and the belt was still tight.. ahhh
Old Aug 8, 2007 | 05:43 PM
  #235
masterpain's Avatar
It is counter clockwise like he said. You if go clockwise you will loosen the bolt. You do not want to loosen the bolt. The whole pulley will move over a few inches when you push counter clockwise with the wrench. I was thrown off too, it took me about 45 minutes of monkeying around under there before I figured that out because i did not want to break anything.
Old Aug 8, 2007 | 05:54 PM
  #236
jRox's Avatar
hmm. cause i was turning it clockwise and it jst loosened the bolt, not the belt. how come in the directions it says clockwise ? well so i turn it counterclockwise, and it should feel like i'm overtightening it? .. but then the pulley should move over?
Old Aug 8, 2007 | 06:00 PM
  #237
masterpain's Avatar
yep
Old Aug 8, 2007 | 06:04 PM
  #238
Sithlord9849's Avatar
Yeah, the RRM directions are incorrect. I did the same thing, turned it clockwise, and the belt came off easily... because the whole tensioner pully fell off LOL. Anyway yeah, you gotta turn it counter clockwise and it will move the entire pulley. You can do it from underneath by yourself but it really is a *****. The spring on the tension pully is hella strong.
Old Aug 8, 2007 | 06:06 PM
  #239
masterpain's Avatar
That is true watch your knuckles!!
Old Aug 8, 2007 | 06:42 PM
  #240
jRox's Avatar
^^i already did.
anyway.. thanks for the help guys. gona do attempt #5,872 tomoro.
