One emmissions problem straight to another.
Old Jul 10, 2007 | 03:18 PM
JasonKnight's Avatar
2002 Lanzer OZ
Ok, a month ago I had my Cat replaced by the Dealership becuase of a code that was being pulled and it was all under warrenty. I forget the code...
Anyway, exactly 1 month later I am now pulling 2 codes
1: P0441 Evaporative Emission Control System Incorrect Purge Flow
and
2: P0452 Evaporative Emission Control System Pressure Sensor Low Input
now from the problem I had before could these be related in some way shape or form that they might have screwed somehting up when they replaced my cat, or are these 2 things that have nothing to do with a CAT replacement.
Also, what is the fix for both of these codes? or in english terms what is actually wrong.
Thanks
ohh and I did search but all everyone kept doing was posting every single freakin OBDII code that is possible on the cars.
Old Jul 14, 2007 | 12:04 PM
Frankracer88's Avatar
Maybe the Smog pump went bad?
Old Oct 10, 2007 | 01:02 AM
bagice's Avatar
Smog pump???????
The evap system puts a vacume on your fuel tank to check for leaks, the most common leak found on the evap system is someone leaving there gas cap off. If the code hasn't cleared yet go to your auto parts store and have them clear the codes. If the CEL comes back on then you have a leak in your fule system or a valve is sticking or the vacuum pump is bad.
Old Oct 10, 2007 | 06:34 AM
iufan4lifeul's Avatar
emissions are overrated...
drevoviii
24
May 25, 2014 06:48 PM
ch53avitech
Jun 23, 2012 08:35 PM
GBAILEY472
Jan 15, 2010 09:20 AM
projekt_shocker
14
Oct 22, 2008 06:15 PM
BadazzCR
Aug 23, 2008 07:40 AM
