rrm header makes crackling noise?
Old Oct 5, 2007 | 06:11 PM
mitzugsx's Avatar
alright so i got the rrm header installed it. great except till 3-4 k rpm then it starts to make an obnoxious crackling noise. ive read alot of threads and no one once has mentioned it crackles i hate the crackling it makes me look like a cheap ***. i have rrm headers magnaflow high flow cat and a custom solid bent piece of 2.25 inch cat back with a magnaflow ehaxust. what can be making it crackle. it only does it when i hit 3-4k some please help this sucks ruined my day!
Old Oct 5, 2007 | 06:16 PM
kungfugirl's Avatar
so its raspy? did u replace all gaskets? also mine is semi raspy at wot at 304k rpms. its normal.
Old Oct 5, 2007 | 06:24 PM
mitzugsx's Avatar
it sounds like those stupid cheap cheap ebay mufflers that sound like a coffee can we think it has to do with the vibrations are going so fast now you just hear the expolsions out of the engine. but i can only explain it as crackling. so maybe a harmonic resinator will get rid of it
Old Oct 5, 2007 | 07:01 PM
kungfugirl's Avatar
resonator i added did help alot.
Old Oct 5, 2007 | 08:22 PM
atilla's Avatar
yep, the noise is normal. a resonator will fix the issue as kungfu said.
Old Oct 9, 2007 | 11:42 AM
blaze_125's Avatar
hum... crackling in the exhaust note? or crackling as in rattling?
if it's more like rattling, make sure the tab that bolts to the hanger on the block is properly bolted down.
Old Oct 10, 2007 | 06:38 AM
iufan4lifeul's Avatar
I had the same setup with one of the biggest magnaflow resonators you could fit on our cars with a magnaflow oval muffler and it made that crackling honda rice sound. Supposedly magnaflow mufflers aren't too good on our cars when they get a higher volume of air flowing through them (according to RRM). I went with the greddy evo 2 muffler an none of that. When I put all the motor work on though, if the exhaust isn't warmed up and I step on it, it will make the noise. But as soon as it warms up just a tad it goes away and has a REALLY nice exhaust note.
Here is a sound clip of mine...
http://s144.photobucket.com/albums/r...t=100_0875.flv
Creatre
May 17, 2021 03:26 AM
ChipperEvo
Mar 31, 2020 10:23 PM
g0damy0uugly
Lancer Engine Tech
30
May 16, 2006 08:33 AM
Kaane
19
Mar 14, 2005 07:21 AM
Cabo
Oct 6, 2004 10:30 PM
