The time is up...60k miles.
Old Jan 7, 2008 | 02:58 PM
LancerOZ Boy's Avatar
Ok i have 57k miles on the lancer and im starting to shop around for prices in the next few weeks. I gave Mitsu a call for a good laugh . They said $399.99 for a timing belt change. How much did you guys pay to get yours done? I know ill find somewhere cheaper but just looking to see what everyone else payed. I dont know if i want to do it myself cause i have read about how much of a hassle it is.
Old Jan 7, 2008 | 04:13 PM
SLVROZ_03's Avatar
If you have a decent amount of tools and a weekend to set aside (maybe a friend too), it shouldn't be a problem. You can do a T-belt, A/C & P/S belt, alt. belt, water pump, and new tensioner for amount $130 I believe. I purchased my parts from www.mr-auto-parts.com
Good luck!
Old Jan 8, 2008 | 07:25 AM
mcgarvey's Avatar
Timing belts are pretty easy on these. Lots of room. Remove the right side motor mount and the drive belts, and you'll have unobstructed access to that whole front end of the engine. Set the engine to TDC by aligning the marks on the crank pulley. Remove the timing cover and crank pulley (Air tools a big +). Loosen the tensioner and pull the belt off. New belt goes on and button it up, and you're done!
Old Jan 8, 2008 | 02:21 PM
SLVROZ_03's Avatar
Don't forget the clean the crankshaft position sensor good when in there! Like mine, they tend to collect grime and soon your car won't start due to faulty CPS CELs.
Old Jan 8, 2008 | 03:54 PM
lol well i dont plan on doing this myself. Not enough time on the weekends and i dont want to mess something up since i dont plan on keeping it much longer.
Old Jan 8, 2008 | 04:25 PM
sgand's Avatar
-edit-
Old Jan 13, 2008 | 08:53 AM
Instead of starting a new thread ive got another question... I dont plan on keeping the car much longer and in 3k more miles ill be at 60k. I plan on get a STI in 6 months. How long can i go on the timing belt before it breaks? I dont want to spend close to 1k getting all this stuff replaced to turn around and sell the car. Ive read of people getting up to 80k and it hasent broke but i dont know if i want to take the chance of it breaking cause then ill be screwed real bad.
Old Jan 13, 2008 | 08:57 AM
ambystom01's Avatar
I would do the timing belt if I were you. If it snaps you'll be paying a lot more in repairs and when you go to sell it if they find out you haven't done it, they'll be wondering what else you haven't dealt with.
Old Jan 13, 2008 | 11:31 AM
iufan4lifeul's Avatar
I got a water pump, coolant flush, all belts changed, oil change, spark plugs and wires, parts and labor done for $300 at one of the best tuner shops in the ohio valley.
Old Jan 13, 2008 | 11:56 AM
slatermvp's Avatar
is the timing belt the only thing that needs to be done at 60k
Old Jan 13, 2008 | 03:18 PM
SLVROZ_03's Avatar
My factory T-belt looked mint when removed around 73k miles.
Old Jan 13, 2008 | 04:16 PM
I just read a thread on a guys belt that snapped at i believe 67k miles. Seems to be a gamble . Ill probly end up changing it then.
Old Jan 16, 2008 | 08:13 AM
clearskies's Avatar
maybe i should drive my car over there!!!
Old Jan 16, 2008 | 12:02 PM
wOZrally's Avatar
i know yall might gimme some crap but im 105k and i inspected my belt and it looks good no chipping no dry rott looks. i got a new one but kinda scared to mess with it. but mcgarvey! how about u give us a more detailed way to put it in
Old Jan 16, 2008 | 12:05 PM
dsmjeffro's Avatar
mine was easy & free did it my self but let me warn you make sure that oil pump balance shaft is in the correct phase or you will have a vibrating car !!!!
