Random CEL today...
Old Feb 1, 2008 | 05:07 PM
03_Lancer_ES's Avatar
Random CEL today...
Threw a random CEL today...
I haven't got it pulled (anywhere to get that done free in Winnipeg? NAPA doesn't, PartSource doesn't...) but the car still drives fine, idles ok, runs ok.
I just filled up, checked the gas cap, it's tight.
A couple days ago I was turning a corner, and there was a rut in the road, which conspired with the tire track snow ridge in the middle to catch and shatter my front bumper in the -45 weather we so dearly love here. Purely cosmetic damage, so I don't think it's that, but worth mentioning nonetheless. It's the passenger front corner that is broken.
I recently switched to mid-grade gas in preparation for the RRM Piggyback I got, but this is the 3rd tank i've had with that in.
On December 24th, I had the oil changed at Wal Mart, Pennzoil full synthetic 5w30. The bill says they put in 3.8 litres. On idle the engine makes that clicky-diesel engine sound, and when I look into the oil cap it doesn't look...terribly well oiled, but what do I know, I never looked inside there before, and it's not like I can look when the car is running. Also, it's still fairly (-20 or so) cold here, and the car typically has made that noise when it's cold out.
Ideas? I haven't a clue what it could be other than the oil, i'm guessing it would throw a CEL for low oil, right? The dipstick looks fine to me though. The coolant is fine, and at a good level. The engine temperature guage is right where it always is, it's not running hot either.
Old Feb 1, 2008 | 05:55 PM
Yeah, I know but apparently oil levels won't throw a CEL i'm told now and I doubt you'd be lining up to change your own oil in -50 weather ha ha ha .
Old Feb 9, 2008 | 11:49 AM
wOZrally's Avatar
one great thing to run in the winter is Full synthetic Lucus Oil Stabilizer. pricey but you can hear the difference
Old Feb 11, 2008 | 01:28 PM
mcgarvey's Avatar
Let me get this straight.. you tried to check your oil by looking under the filler cap?
There's a dipstick, you know. If you're concerned about the oil level, check it with the dipstick. And if you have a code, get it read and post it on here.
Old Feb 11, 2008 | 03:29 PM
Ha ha, no, I was just looking in the cap to see if the oil was getting up there as well.
The code is P0421 Warm Up Catalyst Efficiency below threshold, it's a recall or something of that nature, I the technical bulletin. Apparently I just have to take it in for some PCM tweak or something, that's what the tech said. I'm not really sure if I care or not...
Old Feb 11, 2008 | 04:06 PM
SLVROZ_03's Avatar
^I had that error, but then it disappeared and didn't show up again. Random occurrence I guess.
Old Feb 11, 2008 | 11:23 PM
styleN_oz's Avatar
Low oil? isnt what the idiot light if for? -50 weather...eek! Do you have the service manaul? Maybe in there it will tell you what the OBDII code really means.
XinnKoda
Lancer Troubleshooting
Feb 1, 2016 08:58 AM
abevAWD
Jun 4, 2015 06:32 AM
EvolNinja
Apr 8, 2008 12:38 PM
Lumpy
20
Dec 18, 2007 02:19 PM
Swashbuckler
74
Oct 20, 2007 12:14 PM
