vacuum gauge
Old Feb 29, 2008 | 12:03 PM
srv2790's Avatar
vacuum gauge
recently hooked up my vacuum gauge and wen the car is at idle the needle ticks back and forth not extremely distant but very rapidly. definately thinking its a stuck valve ne other suggestions?
Old Feb 29, 2008 | 12:18 PM
ambystom01's Avatar
Could just be the gauge.
Old Feb 29, 2008 | 12:45 PM
SLVROZ_03's Avatar
What vac source did you tap into? What brand gauge?
Old Feb 29, 2008 | 03:37 PM
lancerrally45's Avatar
how much vacuum is showing up?
Old Mar 1, 2008 | 10:22 PM
CHOZEN_Lancer's Avatar
i hooked up my vac gauge into the same line the FPR is at and it seemed to affect the vac signal that goes to the FPR. The engine seems to bog a little. However the gauge works fine. my gauge is from GlowShift
Old Mar 1, 2008 | 11:15 PM
srv2790's Avatar
it is a mitsubishi gauge its from the evo mr i have all 3. i tapped int the vacuum line towaeds the front of the intake manifold the really thick one. and no the is no leaks from the vacuum line
Old Mar 2, 2008 | 07:12 AM
NwO2kMouse's Avatar
by really thick one u dont mean the one that goes to the valve cover right? the one with the pcv valve
Old Mar 2, 2008 | 12:57 PM
srv2790's Avatar
no. i dont have a line running to the valve cover i have a breather on it cuz i have a custom made intake with no valve for a vacuum line. i have it hooked up to the port on the manifold itself the the hose makes a perfect curve
1091x
Apr 28, 2015 04:23 PM
Babs
Nov 3, 2009 01:13 PM
PorkRoll
19
Nov 12, 2007 10:50 AM
evo8forme
11
Aug 16, 2005 10:08 AM
nexium4
Mar 10, 2005 07:55 AM
