Why no battery relocation kit
Old Jan 13, 2009 | 03:42 PM
elpoole's Avatar
I thought for sure someone would have put a battery relocation kit together. Why Not?
Old Jan 13, 2009 | 05:55 PM
krnkimchi702's Avatar
costs too much..the weight savings for the front would be countered by the extra wiring for the battery.. also i believe you need to buy special batteries since it is inside the car... i think...
Old Jan 13, 2009 | 07:54 PM
evo_soul's Avatar
its coming, I have talked to some of my asian contacts, there is something in the works, lol but they did use something along the lines of "Its Crude" Which means warranty for Electrical could go out the window
Old Jan 13, 2009 | 08:28 PM
pimpinfern's Avatar
battery relocation isnt to save weight, its to DISTRIBUTE weight more evenly for better control
Old Jan 13, 2009 | 08:34 PM
Gumby56's Avatar
evo guys usally runs mini batterys ... just put a mini battery in the trunk
Old Jan 13, 2009 | 08:36 PM
ambystom01's Avatar
Your car has been out for 2 years, manufacturers/tuners are still working on the basics let alone mods that are only aimed at a handful of people. Relocating the battery has nothing to do with weight savings as pimpinfern pointed out, it's to remove weight from the front to aid in handling and to allow for intercooler pipes and things of that nature. You don't necessarily need a different kind of battery (a solid-state battery like Braille or Odyssey offer) but it certainly helps. The main things you need are wiring, a vented battery box and a kill switch. Whether it offers any advantages is debatable and unless you are turboing the car tomorrow and getting custom pipes made, you don't need it.
Old Jan 14, 2009 | 11:07 AM
elpoole's Avatar
A battery wieghs what... about 20 - 25 lbs. Taking that weight off the front and moving to the back is a plus for distribution, i would think.
Getting it out of the way of possible IC and intake opens the door for more efficient designs as well.
Flossing through the car is easy as hell. I know, I installed a rear view camera myself.
If there was a kit out there, I would do it.
Old Jan 14, 2009 | 11:43 AM
ambystom01's Avatar
It's not enough to notice, 20 lbs is basically the spare tire or a full tank of washer fluid.
Old Jan 14, 2009 | 01:33 PM
4g94T's Avatar
I'd rather get a mini battery. I have the oddysey mini battery, I think it's the same one that buschur racing uses. It's small enough and gave me room for intercooler piping.
Some tracks don't allow batteries in the trunk also, if you decide to track your car
Old Jan 14, 2009 | 02:22 PM
Stuntfly02's Avatar
i think all tracks allow it, it is just that they REQUIRE you to install a battery shutoff switch that is accessabe from the cabin of the car. i dont ever remember hearong of someone not being able to run based only on the fact the battery is in the rear...i am sure it had to do with the shutoff switch.
Old Jan 14, 2009 | 02:27 PM
Cyloc's Avatar
There are battery relocation kits out there. Stm Sells a kit with all the wiring and breakers for a good price. The only thing it does not include is a tray. But is you are crafty you can figure out how to use the stock tray in the trunk with the stock tie down.
As for the battery being in the car....The only thing you need is a sealed or solid core battery.
Plus mini batteries tend not to hold up to well in the cold.
Old Jan 14, 2009 | 02:29 PM
ambystom01's Avatar
I'm pretty sure some tracks won't allow it unless you do a damn good job on it. Quite a few require that you have a kill switch that is accessible from outside the car in case of a fire or accident (what good is a kill switch that's inside?).
Old Jan 14, 2009 | 04:00 PM
nj_08_gts's Avatar
Tracks don't care where the battery is for daily driver/track day cars. Miata batteries...and Evo X batteries, too...are in the trunk (along with many other cars), so having a battery in the trunk isn't an issue. It really only becomes an issue when you're racing in a class that may not allow battery relocation or if the battery itself is not properly boxed and/or secured in the cases where it is located in the trunk or cabin.
As far as a relocation kit goes for the Lancer; our car is so damn front heavy I really can't see moving the battery rearwards making that big an impact on performance. It would free up a fair amount of space under the hood, though...can't argue that.
Old Jan 14, 2009 | 04:02 PM
ambystom01's Avatar
If they came from the factory with the battery in the trunk, it's a different story since they would have already had to pass safety just to be considered road legal.
Old Jan 14, 2009 | 04:10 PM
nj_08_gts's Avatar
True - guess I should have worded that a different way : If the battery is moved from the stock location, it's OK for track use as long as it secured, boxed, and you don't have bare wires stretching through the car. A couple of times, I've seen them used as ballast.
genesisevo
Feb 3, 2016 11:40 AM
BoneEvo9
Oct 13, 2014 03:30 PM
jager89
Apr 11, 2013 06:44 PM
MLucas13
Mar 6, 2013 06:54 PM
alenewit3928
Mar 27, 2011 10:16 PM
