new intake,wierd idle
Old Jan 24, 2009 | 04:37 AM
rockmySOHC's Avatar
okay so i just bought an intake system..
fought wid the maf to get it unbolted..
put the new filter nblah blah.. blahh... start up my car its fine take it for a drive and come back the idle is around 600 and bounces between 1000ish to near stalling and sometimes stalls out, CEL turned on after driving it one more time.. any advice on how to solve this? or is this even common? im pretty sure(not 100% but ill check them again tomorrow) everything is bolted on tight.
Old Jan 24, 2009 | 08:00 AM
llt-racing's Avatar
Is there a gasket in between maf adaptor and maf? A leaking maf causes a lot of incorrect signals relayed to the ECU so check that for starters.
Old Jan 24, 2009 | 05:38 PM
rockmySOHC's Avatar
naw my kit didnt come wid one.. and the stock didnt have if i remember rite so i thought it would be okay 0.o ahh well ill try seal that thing up thenns.
Old Jan 24, 2009 | 05:52 PM
doctorjon's Avatar
Did your intake kit come with a MAF adapter?
Old Jan 24, 2009 | 05:58 PM
ambystom01's Avatar
Did you reset the ECU?
Old Jan 24, 2009 | 06:22 PM
rockmySOHC's Avatar
yeah intake came wid maf adapter.. but no gasket wid it -_- and yes i tried a ecu reset.. imma go to checkers and try seal the adapter and maf.
Old Jan 25, 2009 | 01:57 AM
rockmySOHC's Avatar
okay update.. so i checked the maf.. and sealed it wid gasket maker.. bolted all back up drove my car and it was fine.. cruzed around for a few hours.. when i went to my car again to start it all my elecrtical was not working as if i had a dead battery... so we jumped the car to find that my battery was loose.. okay maybe my fault.. then start the car agen but once i start the car it sputters and dies.. it did it everytime i tried.. about 6 tries..
so out of curiousity.. i unplug the wires leading to the maf and try start the car.. now the car runs perfectlly fine.. did anyone have this issue? i mean from what a friend of mines wid a 240sx said was his car is the opposite, take off the maf sensor car dies..but why did my car work better without the maf plugged on?
Old Jan 25, 2009 | 05:47 AM
llt-racing's Avatar
i had that issue but that was because my MAF was not in good condition as in the honey comb shapes where obstructed.
Old Jan 25, 2009 | 01:05 PM
rockmySOHC's Avatar
oh yeah.. i kinda hit a few of mines.. 0.o any way to solve it?
Old Jan 25, 2009 | 01:18 PM
Demon_ni2's Avatar
hrmm.. sounds like you are mising a vac line or possibly something with the maf is dissconnected. you shouldnt be having any problems with just an intake swap..
check all the connections and make sure you didnt leave anything undone (also make sure the maf is pointed the right direction, i know the stock maf enclosure is direction sensitive)
Old Jan 25, 2009 | 11:31 PM
rockmySOHC's Avatar
problem fixed (: thanks for all the quick replies. and help
chopzilla
Jul 7, 2019 10:09 PM
UnholyMaggot
Jul 11, 2016 09:46 PM
hotredevo
Jul 29, 2010 06:54 AM
08 Evo X MR
Dec 30, 2009 06:26 PM
mr1444
May 23, 2008 10:18 PM
