Power loss
Old Mar 4, 2009 | 12:32 PM
AtomicQtip's Avatar
Power loss
Lately my 08 lancer has been driving like ***. It doesn't have the pull above 3000 rpms that it had and it is more likely to bog down in the low rpms. There is also a definate change in exhaust/intake/engine noise right around 3200 rpms that was never there before. It almost sounds like a have an intake which is kind of weird because my car is completely stock. I have only 20000 miles on my car I don't think that stuff like this should be happening so early in the life of the car. Anyone have any ideas what it could be? Any help is appreciated.
Old Mar 4, 2009 | 12:41 PM
ambystom01's Avatar
Is it throwing any codes?
Old Mar 4, 2009 | 12:52 PM
sloAZevo's Avatar
faulty coilpack? Sparkplugs? Massive vac leak, like around the tb/manifold area? If its an 08 take it to a good dealer and have them figure it out warranty ftw.
Old Mar 4, 2009 | 04:18 PM
anbuzero's Avatar
have u changed ur oil regularly, i noticed an increase in power and gas milage after an oil change.
Old Mar 4, 2009 | 06:36 PM
nj_08_gts's Avatar
The bog issue is a known problem - the dealership needs to flash your ECU. Or, since you did mention more noise, did you change your air filter recently? Sometimes not closing the air box all the way will cause similar symptoms.
Old Mar 4, 2009 | 09:55 PM
cRc`22's Avatar
check if ur airbox is clamped down properly.. mine sounded like a shortram when i didnt close it right the first time
Old Mar 6, 2009 | 12:02 AM
AtomicQtip's Avatar
Is there a secret to getting it to close right? I did recently check my air filter and I thought i closed it right but the signs are pointing to no. Ill play around with it tomorrow and see if it is the problem.
Old Mar 6, 2009 | 04:33 AM
EngRWW33's Avatar
The bottom clips are the trick... That is all
Old Mar 6, 2009 | 07:44 PM
Bladed's Avatar
I should check my air box tomorrow. I took it to jiffy lube to get an oil change and they checked my air filter and now it sounds really cool as if I have an intake installed, but its completely stock so I should close it properly.
Old Mar 7, 2009 | 12:25 AM
AtomicQtip's Avatar
Problem solved. Those bottom clips are a *****. I didn't even notice they were there and the air filter appeared to be seated properly.
Old Mar 7, 2009 | 05:32 AM
EngRWW33's Avatar
Good to hear
Old Mar 13, 2009 | 04:49 AM
ejlancer's Avatar
damn ur lucky it was something that easy to fix
Old Mar 13, 2009 | 11:24 AM
slaker138's Avatar
yea he is, man o man. sure he laughs at it now, good to know theres nothin wrong with the ride =]
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
s240
26
Oct 23, 2015 04:37 PM
yang123
14
Sep 18, 2007 03:15 PM
Evo23IG
Jun 13, 2007 02:31 PM
apexeight
20
Jan 26, 2005 08:20 PM
