Best products for N/A OZ Lancer
vision imports has them. And also, go with a 2.25" cat back exhaust. Then buy the RRM Test Pipe. Get the air intake also. And believe it or not, that Tornado Air thing does work and suck more air in.
Originally posted by HobieKopek
Definitely a good start. So you know, the RPW header comes with a downpipe.
if you're worried aout CEL and want the test pipe, bigjoshracing.com sells a great CEL fix that you just splice into the wires of the 2nd O2 sensor. It tricks the ECU into thinking that the #2 O2 is reading a lower voltage than O2 #1. Well worth the $15.
