what is a performance tune?
Old Jun 26, 2009 | 09:05 PM
smoke's Avatar
what does a mechanic do exactly when he "tunes" your car performance wise not maintenance...?
Old Jun 26, 2009 | 09:08 PM
scorke's Avatar
Adjusts the ECU's parameters to make better use of the air and fuel your car is able to injest, usually comprised of leaning the car out and adding timing, but that is it in it's simplest form.
Scorke
Old Jun 26, 2009 | 09:13 PM
Chabada15's Avatar
Originally Posted by scorke
Adjusts the ECU's parameters to make better use of the air and fuel your car is able to inject, usually comprised of leaning the car out and adding timing, but that is it in it's simplest form.
Scorke
pretty much a perfect answer
Old Jun 28, 2009 | 04:01 PM
smoke's Avatar
how often do you need to tune? i have SRI, hi flow cat, and catback. do i tune now and then get a piggy back then tune again or should i just wait?
how much gain can one expect from a tune and how much would it cost
Old Jun 28, 2009 | 06:41 PM
Stuntfly02's Avatar
If you are going to get a tune do not get a piggyback ECU it in effect does the same sort of thing. Get a tune after you put most of your performance items on. Usually though a NA car is only going to be able to be tuned to a certain point before it is no longer suitable for a daily driver.
Old Jun 28, 2009 | 06:55 PM
LancerEVA06's Avatar
+1 I have a very aggressive tune and cam on my ES... on hot days idle lopes bad enough people think there is something seriously wrong with the car. I dont mind it tho. My 85 Mustang was a lot worse. Had to 2 foot it anytime it got over 75°.
Old Jul 1, 2009 | 09:42 AM
blackdiamonds's Avatar
Originally Posted by LancerEVA06
+1 I have a very aggressive tune and cams on my ES... on hot days idle lopes bad enough people think there is something seriously wrong with the car. I dont mind it tho. My 85 Mustang was a lot worse. Had to 2 foot it anytime it got over 75°.
75 is a cold day in Miami
Old Jul 1, 2009 | 09:46 AM
Blayq Owns You's Avatar
Basically winter temps
Old Jul 1, 2009 | 06:17 PM
Come up to norther Indiana right now... we'll have a cookout and all... and you can enjoy the 61° weather.
Verlassene
Feb 27, 2016 06:20 AM
SLOWRREX
28
Jun 6, 2008 01:50 AM
The_Predat0r
Automotosports - Illinois
59
Aug 20, 2007 11:13 AM
sndm
Aug 16, 2006 09:38 AM
electricevo
Mar 4, 2005 03:40 PM
