Foam intake filter Q?????
Old Oct 13, 2003 | 07:40 AM
lancer02Josh's Avatar
ok so i have heard that weapon R intakes suck because foam filters suck..... but i see that HKS uses foam filters too and they dont have a bad rep... well i dont hear too much about thier intakes but anybody have comments... im thinkin of making an intake but i wanna get a good filter. thanks
Old Oct 13, 2003 | 07:43 AM
cerfur's Avatar
just go with k&n there is already numnorus threads on this subject you should run a search
Old Oct 13, 2003 | 11:51 AM
phatgdog69's Avatar
Heh, kinda like mine right below this one...
Anyway, as far as I can tell, general concensus is that the Ralli||Art is the best, folowed by (or tied with) K&N, then RMR. HKS is always good, but it looks sorta flimsy and nobody has any idea how good it is....but it is the least expensive of all of them.
Old Oct 13, 2003 | 09:59 PM
happycharly's Avatar
i have a reactive cone foam filter on my 03 oz lancer its in my custome ram air kit and the one pluss about foam is you can just wash it out when it gets dirty without needing any re charging agents pluss this might sound sick but actually suck through a good foam filter and then through any other kind of filter you cant even tell your sucking through a foam filter.
Old Oct 13, 2003 | 10:02 PM
oh and another thing i changed from k&n to a reactive foam filter it let so much more air in that i had to reprogram my apexi fuel management system to comppersate for the extra air. so in my opinion i have tried just about all the different kind of filters and the reactive foam is the best ive found yet plus its so eazy to clean.
Old Oct 13, 2003 | 11:58 PM
pjal84's Avatar
My HKS SMF setup filters better than my drop in K&N panel did, and the SMF is the same oiled foam element as the HKS panel. Easy to tell since when I had my stock airbox I would make sure to lightly clean off the MAS honeycomby when I'd clean/re-oil my filter and now with my SMF, I can slide off the elbow and look at the honeycomb and less dust comes off when I replace the elements. The fact that the SMF element can trap dirt in a multidimensional area is a big plus if you ask me. When the filter needs replacement, you can see how the most dirt collects on the large pored surface of the element and then less and less as you work down, almost like the rings of a tree.
Old Oct 14, 2003 | 07:26 AM
ok so that HKS SMF is drop in right... also i just heard that foam filters need alot of care, and they have to be replaced alot more that norm filters... oh plus if my car is stock and the foam is sucking in more air.. wouldnt that be too much. my car would be runnning lean right? (which isnt good,right?)
Old Oct 14, 2003 | 11:02 AM
pjal84's Avatar
Just remember, again, my car has an intake kit, not just a panel, but the filtering medium is still the same: oil impregnated multi-density foam. With the HKS elements, you don't re-use, you just buy a new one every few thousand miles. I do it at about 5k, just a little bit after each oil change. As for running lean, no intake or panel is gonna force the stock ECU to do that as there's plenty of room for the ECU to adjust. The ECU loves running rich. Simply enough, with an intake, it's just going to give the car more gas to keep the A/F ratio at or near the stock one.
LCS
Dec 1, 2015 03:20 PM
EdT
Lancer Troubleshooting
Sep 20, 2013 04:39 PM
mixlplix
Dec 10, 2012 02:59 PM
italianevo88
Jun 18, 2010 03:03 PM
EclipseMblue
May 26, 2008 09:51 PM
