cat back or axel back?
Old Jan 20, 2010 | 11:55 PM
djslik408's Avatar
I have the magnaflow axleback. It weights a lot lighter than stock and it was also easy to install. At that time there were no cat back available or even a test pipe.
Old Jan 21, 2010 | 02:10 PM
rvcaman's Avatar
i was wondering the same but i think a lot of people simply go axle-back because it doesn't void warranties.
Old Jan 21, 2010 | 03:38 PM
chetman7's Avatar
how about piping size?? keep stock diameter? open it up a bit...I always wonder how big of a piping you can go while non-boosted and still retaining gains/back pressure.
Old Jan 22, 2010 | 02:37 AM
henryDgreat's Avatar
we'll i did some wiki-ing
catback - from catalytic converter to (all d way to the back)exhaust muff
axleback - ??
Old Jan 22, 2010 | 04:20 AM
EngRWW33's Avatar
Axle back = Rear axle back to tip
cat back = cat converter back to tip
header back = header back to tip
Pretty self explanitory.
Old Jan 22, 2010 | 07:24 AM
jeremy_ton's Avatar
Who said a cat back for our cars would give more power than the axle back? I bet you wouldn't notice a difference. Plus cat backs would cost more. I'm pretty sure the cat back setup just sounds cooler to talk about. I'd go RRM past experience here for our cars and get the axle back. Now if we're talking Camaro Z28's or any other V8 engines, then yes go with the cat back.
Last edited by jeremy_ton; Jan 22, 2010 at 07:25 AM. Reason: added "to talk about"
Old Jan 22, 2010 | 07:26 AM
jeremy_ton's Avatar
I don't think there is much restriction in the stock cats for our cars. But I'm no expert.
Old Jan 22, 2010 | 03:14 PM
Bawb3's Avatar
Okay, here are some things to consider.
On a N/A (Naturally Aspirated, No turbo or supercharger) car; You don't want to just throw the biggest diameter exhaust on your car because the engine actually requires back pressure, which is generated by bends, and the diameter of the piping itself. If there is no back pressure, you actually lose horsepower. So if you're wanting a custom fabricated exhaust, don't think getting a 3"+ exhaust is going to do anything but be super loud.
On our Lancers, being that they are N/A, we will not see significant power gains from an axle-back OR a cat-back. The stock exhaust is already 2.25' diameter, which is actually not bad. It's design is pretty straight and fairly free flowing already. The most restrictive piece is the muffler, which is why axel-backs are more common for the lancer.
Adding an extra section of piping (From the catalytic converter to the muffler section of piping) is about the only difference from axle-back to cat-backs, which really doesn't make that much of a difference in performance, however the sound can be different depending on resonators and whatnot.
So when considering what exhaust to get, the biggest thing to consider (in my opinion) is how they sound. Go on youtube and check out videos of different exhausts and decide which one you like the most, regardless if it's axel-back or cat-back. Find people you know or live near you with the exhausts to see how they are, or ask fellow EvoM members how they like whichever exhaust you are considering.
As far as weight reduction; yes most aftermarket exhausts are lighter than stock, but that also makes no difference in performance unless you plan on doing a lot more weight reductions such as small battery kits, carbon fiber body panels, stripping the interior, lightweight wheels/tires, glass replacement, ect. So unless you're planning on making it into a track car, don't worry about the weight.
Old Mar 2, 2010 | 05:14 AM
m.s.p's Avatar
You won't fail if you go with the new BORLA exhaust for our lancers... trustworthy if not best hi tech exhaust company... savin money to get a BORLA...
Old Mar 2, 2010 | 05:22 AM
EngRWW33's Avatar
^^ link?
Old Mar 24, 2010 | 01:39 PM
view's Avatar
Very good explanation thank you
Knightr
Nov 10, 2014 07:45 AM
EVO VIII Chris
29
Oct 1, 2014 06:51 PM
iWiN
Northwest Region
44
Jun 14, 2011 02:14 PM
phantomwilson
Jan 28, 2011 11:34 AM
AbusiveWombat
50
Jul 2, 2003 06:01 PM
