Lancer Camshaft
Old Jan 27, 2010 | 01:05 AM
M@verik's Avatar
Lancer Camshaft
Has anyone made these yet? NA though.
Old Jan 27, 2010 | 08:26 AM
mines hotter's Avatar
jun is the only one i believe
Old Jan 27, 2010 | 07:29 PM
yitzac1990's Avatar
those are for the evo x
Old Jan 28, 2010 | 09:32 AM
they will fit the lancer as well
Old Feb 1, 2010 | 07:19 AM
LS1CRAZY01's Avatar
Thats a completey different set up. And because it works well in an Evo dont mean it will work well with a NA Lancer.
Old Feb 1, 2010 | 10:23 AM
the brian crower stroker kit and pistons and cams work on a lancer a bc rep confirmed it so therefore the jun willl fit as well
Old Feb 1, 2010 | 11:29 AM
ambystom01's Avatar
Fitting and working are two entirely different things.
Old Feb 1, 2010 | 11:43 AM
yitzac1990's Avatar
i DO know that an Evo head wont work on a lancer because of the ECU....it is completely different circuitry. so most likely, Evo X cams wont work on a Lancer, unless you want to swap heads and ECUs as well.
Old Feb 1, 2010 | 11:56 AM
ambystom01's Avatar
The issue isn't fitment, it's application. An Evo kit would be useless for an NA Lancer application.
Old Feb 1, 2010 | 04:28 PM
yitzac1990's Avatar
no no i meant an evo head does actually FIT on a lancer block (im pretty sure) but the circuitry to work the head correctly of the evo is different than the lancer. so basically an evo kit would work, if you also swapped heads, ECUs, and most likely blocks as well.
Old Feb 2, 2010 | 08:33 PM
Me-So-Bishi's Avatar
Anyone know if a 2.4 gts head will work on a de.
Old Feb 2, 2010 | 08:37 PM
TopTuner's Avatar
or if the 4b11t head will fit, with the 4b11 cams in it
Old Feb 18, 2010 | 12:00 AM
M@verik's Avatar
U will actually make less power with that as the compression ratio will drop significantly. Our lancers have a compression ration of 10, while evos have about 8. That is why the evo makes less hp than the stock lancer when u take the turbo off...
Old Feb 20, 2010 | 10:58 PM
JHizzle's Avatar
it would be nice if someone made it..surprised RRM hasnt hopped on this already. most lancer owners dont really want to be boosted. they just want to be fast enough to enjoy the car. which a 200whp n/a lancer would hit the spot
Old Mar 8, 2010 | 01:00 AM
M@verik's Avatar
Jip, 200whp would hit the spot nicely
